Flashing Cel while driving?
Old Nov 29, 2004 | 05:57 AM
TonyGotSkilz's Avatar
Hey all, got a different problem on this max i never had with my old one, When i start it up in the morning, and only in the morning for some reason the car runs really rough. When i last checked for codes (before cel came on) i got a knock sensor code so i know thats gone and i could tell performance wise before i checked it that it was. But now since then, twice in the morning when i was making a short trip the car ran rough (idle'd smooth but accelerated roughly) and then the check engine light began to flash (not throwing a code just on off on off). And after driving for like 5 more minutes it stayed on static. Then upon starting it up later it was off and car ran normal (this was 4-5 days ago) nothing has happened for awhile then this morning it happened again. Haven't had a chance to check the codes but will later. Any Clue as to what this might be? I'm thinking bad ignition coil, that sound right? Any helps appreciated and i'm a 95 5-speed btw.
Old Nov 29, 2004 | 06:18 AM
Maxima99SE's Avatar
will fly for food
flashing CEL means misfire and it's very bad to drive when it's flashing.... check your ignition coils... sounds like they may have gone out...
Old Nov 29, 2004 | 08:49 AM
cardana24's Avatar
Blown
also it may be flashing because you left it in diagnostic mode....I would try re setting it again
Old Nov 29, 2004 | 09:29 AM
Yeah i'm pretty sure its my coils, i know i took it out of diagnostic mode, + it doesn't happen everytime i drive, and it definitely feels like misfiring. Lovely! looks like i'll be buying some coils, now to isolate which one, will the ECU throw a specific code for each or how should i go about telling which is misfiring?
Old Nov 29, 2004 | 09:32 AM
Maxima99SE's Avatar
will fly for food
my car pulled the same crap with me with the flashing CEL a couple of times last year... only twice and it hasn't happened since then, I know I have 2 coils going bad as I tested them with an ohm meter and 2 of them came up with readings way out of spec... I don't have a CEL with them because the problem is only intermittent.. if a coil goes out completely, you'll get a cel.
Old Nov 29, 2004 | 09:44 AM
cool i'll just have to break out the ohm meter when i have some free time and check i'm sure i've got at least one misfiring maybe more <shrug>, thanx for the help guys
Old Nov 29, 2004 | 11:08 AM
95bluse's Avatar
'95's rarely have coil pack failures, it's most likely an injector..which sucks since they cost twice as a coil. I've had to change my #1 injector a few months back. I remember that I once had a similar issue like yours, except she idled rough too, that time i think the IACV was sticky or something. you may want to take it off and clean it...nothing to lose right?
Old Nov 29, 2004 | 02:56 PM
maxima_kid's Avatar
Yea its the coils. Better get it checked out before something BLOWS! No but misfiring leads to internal damages.
Old Nov 30, 2004 | 08:06 AM
Yeap its coil number 6 got the code this morning, 0603...... Got a question now, which coil is number 6? is it passengers side or drivers, and is it back 3 or front 3? I'd guess drivers side back one, but its a japanaese car lol so the order might not make any sense to me
Old Nov 30, 2004 | 09:31 AM
gto400no1's Avatar
usually means missfire but i know it did it to me once because i left it in diagnosic mode by mistake when i tryed resetting the ecu when my o2 sensor triggered my cel. Good luck
-Tom
Old Nov 30, 2004 | 11:48 AM
emmas97's Avatar
tilleys99 says #6 coil is the one on the front drivers side...
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
Colossus
Sep 9, 2015 05:46 AM
intimidator
Sep 5, 2015 07:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
