Re: Leaking at brake area
Old Dec 1, 2004 | 04:09 PM
ZeRo MaX's Avatar
I'm leaking some kind of grease or oil at the break area... it might be my strut... but i'm not sure... it got all over my wheels too... my 4th gen is starting to get me mad... a bunch of problems with it.... but what are some signs of a strut leaking or maybe it's something else?!
HELP ME!
Old Dec 1, 2004 | 04:11 PM
Ant96GLE's Avatar
If its up front its your axle that busted. CHeck the axle boots.
Old Dec 1, 2004 | 04:12 PM
Terran's Avatar
Is it the front? Could be CVs.
A leaking strut would be right around the top of the stut body were the piston goes into it.
Old Dec 1, 2004 | 04:14 PM
Ant96GLE's Avatar
If its a leaking strut it wouldnt be grease, it would be like motor oil but thinner.
Old Dec 1, 2004 | 04:16 PM
ZeRo MaX's Avatar
it might be the axle then.... it's right before the rotors... leaking a lot of grease... what happens if this has happen for a LONG time?
how much to fix it?
Could it be the CV joints?
Old Dec 1, 2004 | 04:18 PM
Ant96GLE's Avatar
Axles = CV joints.. check your boots and see if they are torn. If they are get them fixed as soon as you can. I had a friend who ran his Caravan with a bad axle and it snapped right at the joint.
Old Dec 1, 2004 | 05:00 PM
Terran's Avatar
Yeah sorry about that. I didn't see his post until after I posted. CVs=axles. You could get rebuilds from autozone for about $75 after core return. Raxles.com uses new joints (the part that wears out), but are $125 or $150 (don't remember which) after core. And then about an hours labor (~$50) or do it yourself with the instructions on motorvate (probably more than an hour for a non professional).
Old Dec 1, 2004 | 05:09 PM
Ant96GLE's Avatar
no Terran I know that you know its the same, he just questioned it so I wnated to clarify.
Old Dec 1, 2004 | 05:14 PM
Terran's Avatar
Yeah I was just apologizing for the confusion.
Old Dec 1, 2004 | 08:10 PM
Broaner's Avatar
2060lbs and falling...
Which side? Auto? If pass side and auto I have an axle with 10K on it that I'll send to you. PM me if your interested. If you don't get it fixed there is a possibility that a rock will get stuck in the knuckle of the CV joint and then its gonna do some terrible stuff to your tranny.
Terran the price of labor depends on which side it is. The driver side can be done in about 15 minutes but the pass side is at least an hour. Especially with OEM y-pipe.
Old Dec 1, 2004 | 08:21 PM
Terran's Avatar
That's the quote I got back when mine were broken. Ended up doing it with a mechanic at work so I didn't pay that much for it.
Old Dec 2, 2004 | 02:05 PM
ZeRo MaX's Avatar
So I'm guessing I should get it fixed ASAP?
How do i know for sure if it's a CV joint?
Old Dec 2, 2004 | 03:34 PM
Ant96GLE's Avatar
Check the boots to see if they are torn
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
