Squeaking dash....help please
Old Dec 3, 2004 | 09:32 AM
Kehops's Avatar
Squeaking dash....please help
I have this problem with my dash, could be borderline compulsive. But every significant bump I hit (being in Canada means pretty much every bump), I get this cracking sound coming from the dash section where the digital clock is with Hazard and defoger on each side. It seems to be forming a gap between the joint for that section and the climate control dash section. Clips on both sides are firmly attached, but I can push in between to recreate the noise and I feel it moving. I know this is a weird question but anything that can be done for this?
Old Dec 3, 2004 | 10:21 AM
chenzarino's Avatar
PUll the top piece off and check for anything stuck in there
Old Dec 3, 2004 | 10:31 AM
meanbean's Avatar
I used double sided tape to act like a cushion on the areas that the dash makes contact. just start experimenting where you think the sound is coming from by applying the tape and then reassemble and take a test drive. I had the same noise you seem to have and this took care of it for me.
Old Dec 3, 2004 | 10:33 AM
Kehops's Avatar
I'll give it a shot. Thanks
Old Dec 3, 2004 | 11:27 AM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=267096
Old Dec 3, 2004 | 11:29 AM
Kehops's Avatar
Wow that's great
Old Dec 3, 2004 | 04:09 PM
NetFurie's Avatar
I read over this. Why would you want to put squeak tape all over it? Seems like you'd want anti-squeak tape.
And on that note... where might one get anti-squeak tape? Need something super thin to go around the plastic shifter piece and around the entire center console. The door/window stuff at home depot is too thick.
Old Dec 3, 2004 | 04:16 PM
Ant96GLE's Avatar
Your joking right?
As to where to find some, try autozone or pep boys
Old Dec 4, 2004 | 07:59 AM
greenmax95se's Avatar
take a hammer, and lift it, and bash the dash til it stops.
-rafal
Old Dec 4, 2004 | 07:32 PM
philly96maxima's Avatar
[QUOTE=NetFurie]I read over this. Why would you want to put squeak tape all over it? Seems like you'd want anti-squeak tape.
yes youu are.....
Old Dec 5, 2004 | 02:42 PM
NetFurie's Avatar
Originally Posted by Ant96GLE
Your joking right?
yes.
plus 6
SusieQQ
Sep 9, 2015 12:14 PM
MikesChevelle
Aug 7, 2015 05:57 PM
Maxima95GLE
Jan 3, 2001 01:35 PM
Eric L.
Jan 1, 2001 01:54 AM
