Alternating Blinking Corner Lights
Old Apr 19, 2001 | 10:46 AM
Brockster's Avatar
After visiting a Max site today, I started think. Hmmmm..., how about if the two front corner & signal lights stayed on whenever the car was running. And hmmmm...., what if the lights would alternate when the turn signal was on. Meaning that a left turn signal would alternate between the corner and the signal lights on the left side. Is this possible? Am I going too far?
Old Apr 19, 2001 | 01:02 PM
JacksMax's Avatar
Check out my .sig below
Jack
Old Apr 19, 2001 | 01:09 PM
arcticfrost96
Hey Brockster take a look website http://www.bol.ucla.edu/~cchiu1/home.html
The have a how 2 section. I have done it. When my lights are off my blinkers and the corner light turn on at the same time. When my lights are on, the blinker and the corner light alternate.
Old Apr 19, 2001 | 10:13 PM
Nismo's Avatar
yes it is. best 10 min free mod Ive ever done
Old Apr 19, 2001 | 10:24 PM
Brockster's Avatar
You guys, always a step ahead. Thanks, I'll have to try the "How 2" from your site
Old Apr 20, 2001 | 12:19 AM
Nismo's Avatar
alt.blinkers
here u go:
http://www.geocities.com/amixam69/nissan/markerblink/
Old Apr 20, 2001 | 01:50 AM
Ch12i5
hmm
i dunno how to deal with electrical wires...i've never tried actaully. can anyone give me a few good tips and details when i do this mod? thanks
Old Apr 20, 2001 | 01:58 AM
Nismo's Avatar
ok, once you take out both lense. you will see 2 wires connected to each bulb socket. (1)cut the black wire in half from the side marker. (2) splice(connect) a new wire from the green wire from the blinker and connect that to the cut black wire to the side marker light. thats it, re install the lense and repeate other side.
just look here it couldnt get any simpler:
Old Apr 20, 2001 | 04:13 AM
Brockster's Avatar
Nismo, will using your "How 2" method also allow the side and signal lights to stay on when the car is running?
Old Apr 20, 2001 | 06:02 PM
bolido2000's Avatar
I feel kind of dumb but.... do I have to cut the green wire from the blinker to connect it to the on coming from the side marker?
Old Apr 20, 2001 | 06:36 PM
LoveMyMaximA
i looked in ur pages and i was wondering does it require a new bulb or can u use the stock bulb that the car comes with?
Old Apr 23, 2001 | 06:30 AM
JacksMax's Avatar
Well, there are several mods there in the .sig, so:
Fogs come on with park lights or high beams
http://web2.airmail.net/scutchen/max...ht.htm#lowfog4
No, no new bulb needed.
Front markers (down on the bumper, on the sides)blink
No new bulbs here.
Make front blinkers (bumper, on the front) stay on
http://csc.smsu.edu/~jack/max/blinkermod.html
Yes, this requires new bulbs, like it says on the webpage. They are 1157s. Required since you are converting a single element bulb and socket to a dual element bulb and socket.
Jack
Old Apr 23, 2001 | 01:58 PM
LoveMyMaximA
yeah i have my signals stay on when i turn the headlights on
No new bulbs here.
Jack
but i was wondering if the markers need new bulbs so they alternate when they blink...can i just use any wire or i have to go to pep boys and get some?
Old Apr 23, 2001 | 02:13 PM
JacksMax's Avatar
Re: yeah i have my signals stay on when i turn the headlights on
For the sidemarker mod? (I have yet to know what mod we're talking about)
For the sidemarker mod, no, no new bulb needed. See, you are taking your old ground wire for it and running it to the HOT wire for the front turn signals. So when the front signal light is ON, your side marker goes OUT (see you have 12V on the positive side and 12V on the negative side, thats why)
The blinking is all done via the 'new ground' you make when you move it.
Jack
Old Apr 23, 2001 | 03:40 PM
Justin95SE's Avatar
so this is basically what you do
cut the ground from the corner lamp and splice that into the + from the blinker. Is that right?
Old Apr 23, 2001 | 03:54 PM
Justin95SE's Avatar
starting to feel dumb
ok, i am seeing 3 wires into the corner lamp, is that right or am i looking in the wrong place? any help would be appreciated.
Old Apr 23, 2001 | 03:57 PM
Justin95SE's Avatar
ooooohhhhh, i am stupid
that was the problem, the sidemarker and the corner lamp are different. So the blinker and the sidemarker are right next to eachother huh.... ok, well is there anyway to get the blinker AND the cornerlamp to flash?
Old Apr 24, 2001 | 06:05 AM
JacksMax's Avatar
Re: so this is basically what you do
Yes, that is correct.
Jack
Old Apr 24, 2001 | 06:23 AM
JacksMax's Avatar
Re: ooooohhhhh, i am stupid
Yeah, it helps to agree on terms! So we all know what light we're talking about.
Make the corners blink too? Hmmm, not tried that. I'd be careful, the bright side of the corner is like 27W, you add the 27 of the front light and you have double the current, then w/o any new heavier harness, you'll have blown fuses.
There's no fast/simple/cheap way to light the corners too that I can see.
Jack
Old Apr 25, 2001 | 12:14 PM
aznbluboy's Avatar
Does this work for all 4th Generations MAX cuz I have a 99MAX.
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
dcardello
Sep 3, 2015 11:44 PM
