Locking/Non-Locking Differential...
Old Dec 4, 2004 | 02:07 PM
_ck69_'s Avatar
I'm trying to replace my CV axle and the parts place asked me if I had a locking differential or traction control. I had no clue. How can you tell?? Please help, thanks.
Old Dec 4, 2004 | 06:25 PM
southeast_first's Avatar
check the second row of your vin plate. if the twelfth letter is N AND you have a manual, you might have it. if either of those things IS NOT true, you don't. not sure how to check if you do have both those things, though, apart from actually spinning your tires while a friend watches to see if they gain traction at the same time.
Old Dec 4, 2004 | 06:36 PM
Terran's Avatar
You're from Canada? You very well could. The US version of the maxima did not, but I believe the Canadian version did.
Old Dec 4, 2004 | 11:42 PM
_ck69_'s Avatar
I was told that if I jacked up the front end and spun one wheel, if the other wheel spins too, that means I have a locking differential. Is this true?
Old Dec 5, 2004 | 12:54 AM
Ninos_Maxima's Avatar
be the change u want2C
Just lift her up, spin one wheel manually with your hands, if the other one spins then you got lsd
Old Dec 5, 2004 | 03:20 AM
_ck69_'s Avatar
I'll try that, thanks.
Old Dec 5, 2004 | 06:52 AM
madmax96's Avatar
if it spends in the same direction right?
Old Dec 6, 2004 | 08:46 AM
Shift_Power's Avatar
Ok..go to the other post..I explained there. Left side under hood on firewall, tranny code. If it has V in it you have LSD (locking), if no V or if it has an A you do not have locking diff.
Old Dec 6, 2004 | 10:04 AM
Akumachan's Avatar
I never narc'd on nobody.
the jack trick, if they spin the same way, LSD, if they spin opposite ways, no LSD. either way, theyre both gonna spin.
maximusmeridius
Jan 27, 2015 02:30 PM
mateusz1945
25
Feb 6, 2011 08:51 AM
876biggs
Nov 12, 2009 07:13 AM
shilov
Nov 13, 2006 10:31 AM
nissanlover
Dec 30, 2004 09:08 PM
