broken oil/engine temp sensor. help
Old Dec 5, 2004 | 03:59 AM
Max Noob's Avatar
the sensor that detects the engine/oil temp is busted. the gage moves very little after have been driven for over 30 mins freeway speeds. the hand is only pointing like 15% of the normal engine temp i have been use.. where is it? is it reachable/fixable. what degree of difficulty is the fix.. anyone know how much the sensor is ..thanks
jimmy
Old Dec 5, 2004 | 06:37 AM
njmaxseltd's Avatar
That sensor detects coolant temp, not engine oil temp. Your thermostat is probably getting weak. Replace it and your engine will run at the proper temperature.
Old Dec 6, 2004 | 02:56 AM
Max Noob's Avatar
if the sensor measures coolant temp.. i dont see the connection between the thermostat and the sensor. if my thermostat were bad, i wouldnt i just be overheating alot. where is the sensor located?
Old Dec 6, 2004 | 10:54 AM
southeast_first's Avatar
your thermostat could be stuck OPEN instead of closed, allowing coolant to flow even when the engine is cold, which would explain why your engine doesn't seem to warm up.
the thermostat is on the front of the right cylinder head.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
zmcneely13
Sep 26, 2015 02:26 PM
