my car was leakin for several months, when i checked the oil today it was BLEOW LOW
Old Dec 5, 2004 | 07:31 PM
2 Da Max's Avatar
i ignored the leak, well not really because i kept parking it in the same spot so i couldnt really tell if it was still leaking or not. i changed the oil pressure switch and it leaks again now from a diff. spot. everytime i rev the engin oil start to drip right above the oil filter. neways wen i checked my oil level today it was below the L. now can this damage my motor or something? or is it already damaged? i am about to put a quart in it tommorow.
Old Dec 6, 2004 | 04:33 AM
chenzarino's Avatar
think of it this way: a car needs oil like you need blood. If you drive with no oil your motor will seize, as in stop and never start again. Fill er up and fix it.
Old Dec 6, 2004 | 07:56 AM
2 Da Max's Avatar
no it has, its like missing a half of a quart. i filled it up today. besides lubrication what else damage did i do?
Old Dec 6, 2004 | 01:46 PM
thisisausername's Avatar
could be fine...or you could have accelerated wear. Oil lubricates, you run a chance of ruining just about everything in your engine without oil.
bearings
piston rings
cylinder walls
valve lifters
ect...
Old Dec 6, 2004 | 01:54 PM
2 Da Max's Avatar
thanks guys
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 13, 2015 12:50 AM
Trin1j23
Aug 12, 2015 08:31 PM
Balkins
Aug 12, 2015 06:39 AM
