why do my h3 fogs keep blowing out?
Old Dec 7, 2004 | 09:51 AM
eckohb's Avatar
as the title says, my fogs continously blow out. i thought maybe i did the rewire wrong, but i went and re traced my steps and everything is fine. i thought maybe it was because of the 100 watt bulbs, so i went to 55 watt, and still the same result. is water somehow getting in there to ruin the connection? i remember once having water in one of the connectors, but arent they designed so that doesnt happen? im hesitant to order h3 hids because of this problem. anyone have this happen to them?
Old Dec 7, 2004 | 10:13 AM
MrEous's Avatar
^ Jeff™
Are you being VERY careful when handling the bulb? Any dirt/oil from your fingers will make the bulb blow out prematurely.
If you suspect water, do you have any kind of condensation during/after rain?
Old Dec 7, 2004 | 10:23 AM
eckohb's Avatar
yes, i wear a pair of those rubber disposable gloves when i install any lights. and i havent checked for condensation, but havent noticed any when installing new bulbs. i noticed some in my cracked corner lights, yet those are still running strong...
i am missing those black tabs for the foglights, would that cause water to get back where its not supposed to?
Old Dec 7, 2004 | 10:42 AM
MrEous's Avatar
^ Jeff™
Have you checked all the connectors to make sure they are keeping constant contact?
Do/did they both go out at the same time?
Old Dec 7, 2004 | 10:49 AM
BlackCat's Avatar
RIP '98 Maxima SE
The black tabs just cover the exposed bolts so no worries there.
Old Dec 7, 2004 | 11:21 AM
eckohb's Avatar
one will go out, then the other will follow shortly. i dunno what you mean by constant contact. there should be constant contact for the bulbs to be on the in the first place. when i take the bulb out, it's blown, so would not having constant contact cause the bulb to literally blow?
Old Dec 7, 2004 | 11:30 AM
bluestealz's Avatar
Jacked Up off MountainDew
had that problem for along time...
get electric tape
peel back the rubber protector on the wire that connects to fog light...seperate the 2 seperate wires by wrapping each piece with electric tape as much as possible. most likely sumthing is touchin there
Old Dec 7, 2004 | 12:01 PM
eckohb's Avatar
hmmm...sounds like ill have to give that one a try after work today. now, do you mean theres' two wires from the foglight, or from the connector?
Old Dec 7, 2004 | 12:04 PM
exit10's Avatar
my right foglight doesnt work but the left does. where should i begin to fix this? are there any write ups on how to do the wireing? i am lost!
Old Dec 7, 2004 | 12:06 PM
eckohb's Avatar
there is a write up on how to re-wire your fog lights so they work independently, but not to fix a problem with you foglight not working. check out the how-tos or the mods
Old Dec 7, 2004 | 12:08 PM
ManualMaxima's Avatar
5th Gen till she dies!
get electric tape
yea alot of time time it is the exposed male and female connection where you plug the fog light into. The bulb is grounded on it base,and alot fo the time when you hit a bump the connection touches where the fog light is being grounded to which = a blown bulb.
do the electrical tape thing onthe iside of the fog light where metal is exposed.
Old Dec 7, 2004 | 12:16 PM
bluestealz's Avatar
not only where metal is exposed....but on the harness itself....just tape up the entire wire....the harness coming from car...not wires on bulb...... i tried everything else before and this is all that worked.
Old Dec 7, 2004 | 12:19 PM
MrEous's Avatar
^ Jeff™
Sorry...just meant to make sure the other wires are connected (by using the electric tape method).
Old Dec 7, 2004 | 12:41 PM
eckohb's Avatar
alright, cool. looks like i got a project for me after work. thanks you guys for all your help. this is why i love the ORG
tarun900
19
Dec 20, 2021 06:57 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
