Hot Maxima
Old Dec 8, 2004 | 09:30 PM
tavarish's Avatar
fwd gone rwd cr00
Hot Maxima
Everytime I drive My maxima for more than an hour on the highway, even if I don't have my heater or ac on, there is hot air flowing onto my leg(most likely from the vents). My leg gets quite hot, and it is sometimes uncomfortable to keep it there. what should i do? this only happens when the car is in motion, so it's not like i can go down there and see where it's coming from, i'm driving. ANy solutions?
Thanx.
Old Dec 8, 2004 | 09:42 PM
Zaypka's Avatar
It’s from the vents. That is the thing i hate about those climate controls in maximas $ infinitys. What u should do is have your inside air sign to be ON that way the air is not going to come in from outside even when ur heat or ac off.
Old Dec 8, 2004 | 10:18 PM
TonyGotSkilz's Avatar
and by inside air he means recycled air the first button on the climate control that looks like a looping arrow inside the car... this closes your vents getting rid of the problem... actually if you turn your AC to cool (or climate control to 65) and turn the system on for a second then off, it should blow cold air at u, if it doesn't thats kinda weird, you've vents might be stuck
Old Dec 8, 2004 | 11:16 PM
Keyser Skoze's Avatar
my old max had that before it got jacked. i would just turn it off and it never let anything inside the car. im willing to bet that the unit isnt working properly.
Old Dec 8, 2004 | 11:33 PM
Taken2DaMax's Avatar
Or you could ghetto rig it. Put cardboard, where the air comes out to hit your leg, to block the air.
Old Dec 9, 2004 | 12:44 AM
007max's Avatar
duct tape > cardboard
(in the book of ghetto rigging anyways)
Old Dec 9, 2004 | 03:06 AM
Zaypka's Avatar
don’t u think that its easier to press the bottom?
Old Dec 9, 2004 | 05:25 AM
vortechpower's Avatar
You don't even have to turn the climate control on. Just push the cold (cool/less temp) buttom to 65 like someone else said. The little blue button. Temp settings can be changed when system is off. Thats what it's made for.
Old Dec 9, 2004 | 06:00 AM
HomerMAC's Avatar
Donating i30 Owner
... can you really..? i didnt think it worked till i turned on the AUTO .. lower the temp... and then it would be nice.. cool air.. its good in teh summer... when im not wearing shoes.... oh man.. on the highway its cool air blowing onto the leg....
Old Dec 9, 2004 | 08:18 AM
tavarish's Avatar
fwd gone rwd cr00
wow, thanks, i never thought of just recirculating the air, it would most likely fix the problem, and i have it on 85 degrees all the time since it's cold as hell in NJ this time of year.
Old Dec 9, 2004 | 10:44 AM
ny96max's Avatar
wow... i cant believe someone actually posted a question like this!
Ant
Old Dec 9, 2004 | 11:30 AM
Max96GLE's Avatar
Thanx.
I have a smiliar problem when I went on a trip. It only gets warm when i'm driving over 60mph. Anything under 60mph, is managable. I took my Intake Air temperature sensor out, thinking that's the sensor I should look into. It regulates how the intake breath. If it's too cold, it warms it up a little. Vice versa. Also, my CEL came on with the code. I reset the CEL twice and that problem when away. I figure I had someting to do with my K&N air filter installed recently.
Lakersallday24
Nov 7, 2024 07:31 PM
Smiley101
Aug 1, 2024 08:02 AM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
egali045
Aug 5, 2015 09:02 AM
