Changing Motor Mounts
Old Dec 10, 2004 | 08:54 PM
SamMan23's Avatar
I want to change all the motor mounts on my car. I'm getting vibration and I know that the engine rocks when it's in gear. Are there any write-ups?
Old Dec 11, 2004 | 08:56 PM
SamMan23's Avatar
anybody do this on their own?
Old Dec 11, 2004 | 09:22 PM
Ant96GLE's Avatar
It looks pretty straight forward... the front and back you have to unscrew 2 screws on the cross member from under the car and take the mount off while supporting the engine somehow...
Old Dec 11, 2004 | 10:08 PM
Dagger969's Avatar
I know the side is different but is the front and rear the same part?
Old Dec 12, 2004 | 06:19 AM
Kevlo911's Avatar
Kevlo for President
Look in the how to's....
Old Dec 12, 2004 | 01:35 PM
Dagger969's Avatar
looked in the stickies where does its say "the front mount is (not) the same as the rear."
Old Dec 12, 2004 | 02:15 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showpost.ph...2&postcount=10
Old Dec 12, 2004 | 11:01 PM
Dagger969's Avatar
I read that. Am I missing that part? A simple yes or no will suffice. This is really pretty asinine. I can understand when a whole write up is desired and you tell someone its in the stickies, but when a yes or no will do, and instead we jockey back and forth....asinine.
I went to auto zone to compare part numbers on the two mounts but the front shows up and the rear doesn't. Normally this would mean that they are different but seeing as how this is auto zone it doesnt mean a whole lot.
Old Dec 12, 2004 | 11:14 PM
Ant96GLE's Avatar
Autozone retards...
I dont know if they are the same or not.. but I used to work at an auto parts store and along with the computer catalog we had books from companies that sold us parts.. for example, a company that makes motor mounts has a book that shows pics of all their motor mounts by part #... the retards at autozone have no clue what they're doing.
Old Dec 12, 2004 | 11:17 PM
Dagger969's Avatar
Originally Posted by Ant96GLE
Autozone retards...
I know, I'm a manager there Thats why I doubt that piece of crap system they have. That POS is wrong all the time.
Old Dec 12, 2004 | 11:19 PM
Ant96GLE's Avatar
thats why I dont go to autozone
Old Dec 12, 2004 | 11:26 PM
Dagger969's Avatar
Haha, but seriously, unlike most other dip****s who will just tell you what you want to hear, I'm on here trying to find out the real issue and having to deal with this crap. Its rarer to go to one of these parts stores and have someone tell you they dont know the answer than it is to find some idiot who's just blowin smoke up your ***.
Old Dec 12, 2004 | 11:54 PM
Ant96GLE's Avatar
Atleast you try.. I'd go to your autozone
Old Dec 13, 2004 | 05:22 AM
JeEvE's Avatar
I have two extra mounts that are sitting right here. There is minor differences between them so, yes they are different.
Old Dec 13, 2004 | 08:07 AM
Dagger969's Avatar
Thanks, I have the back one, and I think thats the one that is bad. But I cant seem to find the front one and I dont want to do all this work and only change out one of them. Seems like a waste of time and I'm sure if the back one is that bad then the front one cant be all that great.
Old Dec 13, 2004 | 08:17 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
put your e-brake on and put your car in reverse with your foot on the brake and the other foot on the accelerator. rev the engine. have a friend look at the engine and see how much it moves. now do the same in D and notice how much the engine rocks. if they are off, then one or more of your motor mounts are bad. if they are the same yet not too much rocking,
i'd check your torque converter as well. as a bad one will vibrate the car.
and look into your harmonic balancer.
and look into your ignition coils as well.
all these things could cause a vibration and hesistation in your engine.
Hope this helps you. Have a Nice Day
Old Dec 13, 2004 | 09:53 AM
Dagger969's Avatar
Actually I have a stick and when i do anything that would torque the engine like shifting, I hear a clink noise. And I just replaced the passenger side CV Joint. So I'm thinking that its a motor mount. I am at school, far away from home, and I have a lift at home, so I'm just trying to take it easy until I can get home.
Old Dec 13, 2004 | 10:09 AM
Dagger969's Avatar
and PS, My flex pipe is destroyed!
Old Dec 13, 2004 | 02:40 PM
Ant96GLE's Avatar
I destroyed my flex pipe too... bad motor mounts will do alot of damage
Old Dec 13, 2004 | 02:59 PM
NmexMAX's Avatar
dot dot dot ...
I too get a lot of drivetrain "slop". This seems like a good spring project.
At least there was no raw meat stated in the write-up (skin gashes)
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
minsbang
Sep 11, 2015 08:48 PM
sdotcarter
Sep 2, 2015 09:53 PM
