How long due struts last??
Old Dec 12, 2004 | 02:58 PM
Max Atlanta's Avatar
My 1999 GLE has 152,xxx and has not had the shocks / struts replaced. How long do these last? I think I am feeling bumps and pot holes more but maybe I'm just mental. Should I have them replaced? What type/ brand should I replace them with? I don't want to lower it or do anything like that. I want a ride at least as good as stock, if not better.
Is this a DIY project or should I bring it to a shop. I have limited nechanical ability. If I bring it to a shop what should I expect to pay. I live in Atlanta so if there are any locals that can recommend a shop that would be great.
TIA
Old Dec 12, 2004 | 03:01 PM
Conrad283's Avatar
I need a truck
There's no set time table on how long they last. Take them and get the checked out.
If have limited mechanical experience, I would not do the install since you'd need to use a spring compressor.
Old Dec 12, 2004 | 03:13 PM
maxima_kid's Avatar
Yea, theres no exact life expectancy for struts. Depends on your driving really.
But I suppose tokico blues are good enough if your stickin with stock springs.
Old Dec 12, 2004 | 03:25 PM
A Flood99's Avatar
you can get the spring compressor from any autozone, napa, pep boys.....it really isn't too bad, especially if you have an air wrench
i did mine and it took about 4 hours one saturday, the first side took the longest since i wasn't using the air wrench; but it is still do-able with just a socket wrench...it'll just take you a while
just get a haynes manual
Old Dec 12, 2004 | 03:48 PM
njmaxseltd's Avatar
Put a set of Tokico Blue performance struts in and your car will ride better then stock. They are basically an OEM replacement unit, but their valved slightly different giving you a more stable, smooth ride.
Old Dec 12, 2004 | 04:04 PM
chenzarino's Avatar
the old way to test your shocks.struts is to push down on the car and if it bounces up and down, they're going.
matts95max
Apr 23, 2025 10:44 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Maxima30
Sep 7, 2015 06:13 PM
