whats a pop charger do? yes, im a noob.
Old Dec 12, 2004 | 06:06 PM
sook's Avatar
it seems that ive seen posts where people have a (k&n) air filter, then sell it because they got a pop charger, or theyre deciding between them, but, noob, i dont know what that means?
learn me?
thanks
Old Dec 12, 2004 | 06:15 PM
Wicked's Avatar
I think the stickies have your awnser.....good luck, tell us what the answer is.
Old Dec 12, 2004 | 06:21 PM
Loe max's Avatar
learn me?
thanks
JWT and Stillen both have popchargers available.
This is a popcharger
This is a panel filter
Old Dec 12, 2004 | 06:25 PM
sook's Avatar
uber helpful, thanks. and since the admins have strange concepts, i cant really search the boards can i? and, im not just sitting around with nothing to do, so i cant read every post either. also, i opened each sticky and used the search function on the browser, without results. thanks tho.
screaming- thanks, but what do i have to do to use a popcharger?
Old Dec 12, 2004 | 06:29 PM
Conrad283's Avatar
I need a truck
It was just proven that the stock intake is better than an intake. So, you might want to stick with stock.
Old Dec 12, 2004 | 06:31 PM
Wicked's Avatar
1.) Answer was in the stickies....all new members are encourageto read them THOUROUGHLY.
2.) You can only search if you are a donating member. It is an incentive for members to donate.
3.) In order to use a pop charger, you have to remove your stock airbox. Then you have to Attach the velocity stack, and finally attach the filter. Good Luck and may you fing all your answers in the stickys.
Old Dec 12, 2004 | 06:32 PM
Wicked's Avatar
Is this true with cai, hybrid intakes too?
EDIT: nm I just saw the thread.
Old Dec 12, 2004 | 06:37 PM
Loe max's Avatar
Everything that you need to mount the popcharger on should come in the box. What you would need to do is remove the stock airbox only, unless you decide to purchase a mid-pipe also.
Old Dec 12, 2004 | 06:39 PM
dawalkster's Avatar
is craving Bojangles
for the most part yes; and if there is a difference it would be +/- 1 or 2hp, nothing that would make a difference anyways. but if you spice up the look of your engine bay and really hear the growl of the vq then go ahead and buy an ebay intake. otherwise, if you dont care about a look or sound mod and strictly buy for performance then keep it stock and save your money for a ypipe.
Old Dec 12, 2004 | 06:45 PM
Terran's Avatar
If your talking about zack342's dyno then both those runs were done with a JWT PC. The stock midpipe did better than the frankencar, but niether run had a panel filter.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trungg86
Sep 4, 2015 04:58 AM
