just installed 300zxtt brake conversion and had 2 questions
Old Dec 12, 2004 | 07:30 PM
-=PK=-Maxima's Avatar
well we just finished putting on 300zx brake setup (calipers, rotors, ss lines) the other night with the help of Andy at TET, and i had 2 questions.
1) when you did your conversion do you REALLY have to press down on your brakes for it to stop? i mean, my brakes feel like mush. i have to slam on the brakes for it to start to work. yes it does feel a little bit better than stock but for it to work you really really REALLY need to press down on the brakes.
2) i hear this grinding noise coming from the front (well coming from the brakes) and it just sounds like to pieces of metal rubbing against each other. happens mostly when i turn the wheel to make a turn or something. i was told that there is a bolt that is a millimeter too long and its hitting/rubbing against the rotor. and that its pretty normal for this kind of a brake job and it will just "sand" it self down. so i was just wondering if anyone else had this problem?
Old Dec 12, 2004 | 07:35 PM
sterlingmaxima's Avatar
bleed your brakes bro change teh fluid to go higher in dot ratings i use 5.1 wagner but dot 4 should suffice
Old Dec 12, 2004 | 07:43 PM
ive already bleeded them.....and i'm using dot 4
Old Dec 12, 2004 | 07:48 PM
Ant96GLE's Avatar
They shouldnt be mushy or any different than stock... the pedal should feel just the same or a little firmer. It sounds like you probably need to bleed them again or something is wrong with your master cylinder... you should feel the car stopping a little quicker and alot less brake fade.
The screw shouldnt be a big deal, it shouldnt be there in the first place if you can take it out, take it out... if its big enough a screw its going to leave a groove in the rotor before it gets shaved off.
Old Dec 12, 2004 | 09:02 PM
A Flood99's Avatar
quick question.......can you harm your master cylinder if you have air in your lines? or is it alright for a few hundred miles.....just wondering if it had any affect on other brake components other than mushiness
Old Dec 12, 2004 | 09:18 PM
Ninos_Maxima's Avatar
be the change u want2C
Your supposed to keep mashing the brake pedal in park untill it gets hard, thats what I do when I change my breaks
Old Dec 12, 2004 | 09:29 PM
michaelnyden's Avatar
did you break in the new pads properly?
follow these instructions, this is what I use for all my friends cars and mine countless times....works great!
http://www.zeckhausen.com/bedding_in_brakes.htm
also, PK, are you going to JGTC with us?
http://forums.maxima.org/showthread.php?t=359036
Old Dec 12, 2004 | 10:03 PM
MDeezy's Avatar
WTF you have to brake in, brake pads and rotors too?!! thought it was plug and play.
learn something new everyday.
have anyone broken in their new brake pads? or just install and go on driving as usual?
Old Dec 13, 2004 | 09:54 AM
maximaintheface's Avatar
my breaks worked fine before i broke them in , but i had the same problem at first as u did and i had to blead the breaks. that didnt work so i re checked the break pads and two of them were messed up. i got them brand new so atleast i got new ones for free.
Old Dec 13, 2004 | 11:06 AM
Pimpmobile's Avatar
I broke in my pads and rotors when i installed them, ran them from 100km to 5km twice then 100 to 0 and sat in park till they cooled with foot off the brakes. Seemed to work
Old Dec 13, 2004 | 01:34 PM
did anyone else get this grinding noise? and i keep getting this burning smell.....smells like burning plastic. its not the same smell as breaking in new pads, its a totally diff smell.
mike, whats goin down with the s/c? when are you gonna slap that puppy on? hit me up sometime to chill.
Old Dec 13, 2004 | 01:59 PM
well...I am in the process of getting everything 2gether to do it on one day...JWT S/C program ecu with new 370cc injectors which I am trying to track down, and nismo adjustable FPR, walbro HP fuel pump, have to sand down the charge piping and repaint it, and send in the supercharger to be rebuilt at vortech...also I need to call stillen and get all the bolts/nuts/washers needed and lastly, gauges and such....I am also going to get an electic exhaust cut-out welded and wired in and possibly some headers to replace my warspeed mandrel Y....I also am going to do a compression test later this month to see if my engine is ready for boost and am in the process of trying to find a 2001 AE LSD 5spd tranny and swap that in with some new raxles and exedy stage 1 I have...(gonna put redline in the that sucker!)...I will definitely give you a ride as soon as it's in!!!
the tranny and injectors are proving hard to track down at a reasonable price!
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
