poor gas mileage on a 1996 I30
Hi,
Newb, here. I have a new to me 1996 I30. I am getting about 20MPG, I thought my gas mileage would be better. More like 25 MPG, since most of my driving is highway driving. Anyway, I have replaced an O2 sensor and have been told that my knock sensor is bad, per the ECU codes. Could the knock sensor cause me to be having this poor gas mileage. The car runs very smoothly right now.
TIA
Lisa
TIA
Lisa
The FAQ's have a lot of good stuff, take a few minutes to read them.
There are so many things that can affect fuel economy though - almost anything regarding the car's condition can change this. Are your tires under/overinflated? Is your suspension properly aligned? Do you use cruise control on the highway? How many miles has it been since your spark plugs have been changed? since your fuel filter was changed? since your air filter was changed? Are you using fuel with a low (less than Premium 93) Octane rating? Also, try running some STP fuel injector cleaner fuel additive when you fill up next time. Just a few thoughts to get you started...good luck!
i have the same problem...getting 18 mpg
changed the spark plugs, air filter, fuel filter, knock sensor, used STP a few times, tires are properly inflated... the only thing is that rear o2 sensor code came up for one day, then just went away... and i am getting code 0505 which means there are no codes at this time...
also i heard that when you are replacing spark plugs, you need to adjust them somehow? I did it my self, and didn't adjust anything, could that be a problem?
what else is causing low mpg?
changed the spark plugs, air filter, fuel filter, knock sensor, used STP a few times, tires are properly inflated... the only thing is that rear o2 sensor code came up for one day, then just went away... and i am getting code 0505 which means there are no codes at this time... also i heard that when you are replacing spark plugs, you need to adjust them somehow? I did it my self, and didn't adjust anything, could that be a problem?
well i guess I get around 21~23 mpg but it's like 60% city driving. The specs for 98 I30 says that the mileage is 21/28 in city/hwy and so i was expecting around 24~25 on 50/50 city/hwy but seems like my car is getting old (~7 yrs!) and hence the drop.
Originally Posted by maxima_kid
Haha, I get 9 miles to the gallon haha ...
I thought my 17-ish was bad. I went down to a little below 17mpg for a while, and when I changed my brakes I discovered they were sticking. Now I can hit 19-20 mpg (with a good amount of city driving). Not great, but I am happy I can hit over 300 miles a tank now (about 325 or so, it was a little over 280 before).
ef9
Oct 4, 2015 08:43 AM
