96 Max Power Steering pump replacement
Looks like I will have to replace my PS Pump. Any suggestions on where to get the best price.
Currently, I have gotten a quote of $138.00 plus $38.00 core fee from Auto Zone, and similar quote from Advance Auto.
Anyone have any bad experiences with the Auto Zone Power Steering Pump?
Sounds like a decent price for it, did you check with the dealership and see how much they are charging? If they are charging a few dollars I'd be better to go with the dealership so you know you have a direct OEM product.
so the 138 plus 38 core makes it $100 for it? or $138 after you return your old pump?
DO you have that nascar type steering going on?
Did your car have any symptoms before it gave out? I don't know if it's my pump, or what but I am having power steering problems on a cold startup. The car will squeek for half a second or less after being cranked and sometimes after I crank it and turn the wheel to the lock it squeals for a few seconds but ends after that. Today however, there was a different feel in the steering wheel. While I was turning it would act normal and smooth for a small part of the turn, and then felt like I had no power steering at all, it would come back, and then off again for most of the turn I made while backing out.
Any ideas? Don't mean to hijack the thread, just trying to find out what is wrong.
Originally Posted by zMax1996
The $138.00 is final cost plus tax.
Dealers want $390.00 average. Installed about $900.00
Not sure what NASCAR steeing means!
![sadpace](https://maxima.org/forums/images/smilies/sadpace.gif)
My PS feels normal.
I have a leak that "may" be coming from the Banjo fitting. Still trying to figure where the leak is coming from. I figure that with 108000 miles I will probably need a new pump. Hope to figure it all out tomorrow.
Originally Posted by MDeezy
have you checked your containt to see if your low on ps fluid? I know my friend with his pathfinder had the smilar squeeking sounds and it turnout he was low.
vingodine
45
05-21-2016 12:46 PM
maxinout93
08-20-2015 02:17 AM
scarletsosa
08-17-2015 09:09 PM
