95/96 vs. 97+ Grill
Old Dec 16, 2004 | 01:36 PM
DR-Max's Avatar
95/96 vs. 97+ Grill
I have read in many threads that the 95/96 grill is shorter than the 97+. I am about to get the 97+ grill and make it fit on my 95 Max. I understand that I have to trim the 2 legs (bumper side) to make it fit. I looked behind the 97+ grill and found that the lower mounting brackets are almost at the end of the legs so you can only trim a small portion of the legs, see pic below:
I read that you have to trim ~1". Does that mean somewhere within one inch? Based on the picture above, there's probably 1/4" that you can trim off of the legs before you get to the lower brackets. So my question is, exactly how much will I have to trim off of the 97+ grill legs w/o cutting off the lower mounting brackets? Do I have to cut off the lower mounting brackets too? If this is so I will toss out the whole project?
Any input is appreciated.
Old Dec 16, 2004 | 01:40 PM
|Bijan|'s Avatar
UCF Lexus
Basically.......cut a LITTLE bit....test fit...cut a lil more....test fit etc etc.
Trial & Error
If all else fails, use zip ties
Old Dec 16, 2004 | 01:47 PM
DR-Max's Avatar
Thanks...I'm just concerned that in order for it to fit, I'd have to cut the legs off. I'm not too crazy about zip ties because in time, it will get brittle and will eventually just snap and before you know it, your grill is flappin' in the wind. That just happened to the mesh grill I made a year ago. I didn't know that half of the zip ties came off and it was flappin and cutting into the grill shell. Now that section is all ugly and scratched up. That is why I am looking for a new grill now.
Trial & Error
Vyrus's Avatar
You should cut 1/4". But like soulfly said, cut and test for your car, then repeat. I don't know where you heard 1"!
-Cyrus
Old Dec 16, 2004 | 01:57 PM
DR-Max's Avatar
This thread for example, post #39. It was also mentioned a few more times in the same thread.
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
The Frye
Feb 3, 2019 08:34 AM
05RLS2
Nov 7, 2016 05:52 PM
ricky7780
Sep 24, 2015 06:50 PM
