Installed Tokico springs w/ Illuminas
Old Dec 16, 2004 | 07:50 PM
Kehops's Avatar
Along with a the Paradox Heavy-duty strut bar. The difference in handling compared to stock is incredible. The car sits really nice with a 2 finger gap and I imagine it'll will settle down a bitmore in the coming weeks. If anyone is looking for a strut bar with form AND function, the PS heavy-duty dresses up the engine beautifully and seems to perform really well. Anyway, just sharing the joy.
Anyone with Illuminas, what is the easiest way to adjust the rear shocks once they are installed? They're set to 5(max) and I'd like to tune them down a little...
Old Dec 16, 2004 | 07:52 PM
jdm71488's Avatar
do you have any pictures of it?
Old Dec 16, 2004 | 07:55 PM
Kehops's Avatar
Not yet, I'll try and take some tomorrow. IT should look good with my 15 inch winter steelies...
Old Dec 16, 2004 | 08:00 PM
jdm71488's Avatar
better than 14's i guess...
Old Dec 16, 2004 | 08:43 PM
vsamoylov
lol
sounds good. i cant wait until i get my Illuminas or unless Tokico will make the new shocks that they just came out for the maxima. also please post pics of the strutbar and the drop.
thanks
Old Dec 16, 2004 | 08:52 PM
dawalkster's Avatar
is craving Bojangles
? about the illuminas- if you set them to the highest comfort will that raise the car up more? or is the drop the same for the firmest setting to the softest?
Old Dec 16, 2004 | 09:18 PM
kraimer21's Avatar
ye, drop is the same, when you adjust the settings, you adjust the stiffness or softness or the shock not the height
Old Dec 17, 2004 | 04:35 AM
MilesA's Avatar
...Anyone with Illuminas, what is the easiest way to adjust the rear shocks once they are installed? They're set to 5(max) and I'd like to tune them down a little...
Get a flashlight, a regular screwdriver and empty your trunk. The adjusters are at the top of each shock near the wheel well. Once you peel back the trunk lining on each side you will see the tops of each shock. You will have to crawl part-way into the trunk. Use your screwdriver to set the adjuster screw to point to the setting you want. Make sure when you do the adjustment the screw clicks fully into the detent for position 1-5.
A good setting is in the 2-4 range. People here seem to favor 3f/3r, 3f/4r or 4f/4r for a firmer ride or possibly 2f/2r for a more cushy ride. I'd suggest starting with 3f/3r, see how you like it and go from there.
Old Dec 17, 2004 | 06:42 AM
Kehops's Avatar
Ya I started off with 5/5 but quickly switched the fronts to 2 since it's pretty cold up here and it was very stiff. You can definitely feel the difference. I'll be re-adjusting the backs tonight, thanks for the info. I'll try and post picks today.
Old Dec 17, 2004 | 06:45 AM
mzmtg's Avatar
Minister of Silly Walks
Wow, and I thought it was a pain to lie on my back next to the car to adjust the rear AGXs...
Old Dec 17, 2004 | 06:47 AM
gtr_rider's Avatar
192.168.1.1
Yea, gets annoying
Old Dec 17, 2004 | 07:00 AM
NetFurie's Avatar
I took another route to getting at the rear struts when I installed them since I knew the freakin' sub would be in the way.
Behind the back seat is a piece of sheetmetal. The struts sit exactly behind this piece of sheetmetal. I cut two semi-circles in the metal right in front of the struts. So now all I have to do is take out the back seat to adjust. Still a pain, but it's only 4 bolts and takes 3 minutes.
Old Dec 17, 2004 | 07:02 AM
Kehops's Avatar
Ya, I think I still prefer doing it from the trunk
Good alternative though...
Old Dec 17, 2004 | 07:07 AM
NetFurie's Avatar
Ya, I think I still prefer doing it from the trunk...
whatever's easier. It's much less work for me to just remove the back seat than it is to unbolt and take out the sub.
Old Dec 17, 2004 | 07:33 AM
MilesA's Avatar
It sounds worse than it really is. Once you've done it a couple of times, it's pretty quick, a couple of minutes at the most. Fortunately, once you find a setting you like, you can leave it alone. I changed it when the weather got cold to soften the ride, this Spring I'll change it back.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
