55watt vs 100watt fog lights
100 Watt bulbs only last a short time in that small housing. Way to much heat is generated which can't be dissapated in the small housing. That causes premature bulb failure.
I really wanted to put higher wattage bulbs in foglights as per they are almost useless, only go maybe 15 feet; I got Piaa xtreme white 55w and removed the bulb metal cover inside housing, looks brighter looking to them but just slightly better on road; I thing the only choice maybe to put HID's.
Got the same problem with headlights; want to put 85w instead of 55w, seems like is possible if change all wires to better ones and add fuses; but not sure if plastic headlights will crack.
100 watts = 8.3 amps... or 16.6 amps total for 2 bulbs.. i wouldnt run that with stock harness man...youll burn them to a crisp... if u ever seen house wiring... that lets about 15 amps through.. now look at the skinny wires to the fog lamps... just buy some silverstars and you will be fine
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
