Window tint removal question
Old Dec 18, 2004 | 02:03 PM
l3ftonm3's Avatar
Well my rear tint started to bubble like mad, so I was a dumbass and just peeled it right off not thinking anything of it, but now I have the leftover glue residue. So I read that using ammonia is good in helping remove it, but would 3m adhesive remover be better? I remember using that stuff when making the door pillars the body color and removing the glue there. I just am trying to figure out the best way so that I dont screw up my rear defroster lines by cutting them with a razor blade if I need to scrape at the window. Thanks
Old Dec 18, 2004 | 02:05 PM
Y2KSESteve's Avatar
A lubricant and razor blades will work the best probably. I've never tried adhesive remover on tint glue before though...
Old Dec 18, 2004 | 02:22 PM
Pimpmobile's Avatar
goo-gone gets almost anything off
Old Dec 18, 2004 | 03:22 PM
chuckie311's Avatar
they way they do it at the tint shops is to put a plastic bag taped around your rear window and spray the window with ammonia and let it sit in the sun for a few hours.
Old Dec 18, 2004 | 06:14 PM
l3ftonm3's Avatar
yah I read about that, but being its winter in ny, I dont think it will get hot enough to effectively work. I do have goo-gone looks like its time to experiment, anyone have any ideas how much to replace rear window defroser if at all possible?
Old Dec 18, 2004 | 10:22 PM
goodhead's Avatar
should have used a steamer to get it off....
Old Dec 21, 2004 | 02:59 PM
l3ftonm3's Avatar
well for anyone who may have this problem in the future or at the momment, I used 3M vinyl and Adhesive remover, and it worked great getting the crap off. Also my rear defroster still works which im very happy about.
Old Dec 21, 2004 | 03:07 PM
Irish's Avatar
This is a democracy
i used a heat gun and razor blades, but not on the back, be careful not to screw up the copper strips for rear window defrost....
Old Dec 21, 2004 | 10:01 PM
goodhead's Avatar
dude the pros use steamers it works wonders jsut try it, go to walmart and buy the ones u use to stream your shirts its one in the same
Old Dec 21, 2004 | 11:57 PM
95whitese's Avatar
i agree, with a steamer i got my back window tint off like nothing, just gotta watch out not to get ur speakers all wet
Old Dec 22, 2004 | 08:33 AM
Mrnissan50's Avatar
paint thinner man and a razor blade its a fun few hours good luck
Old Dec 22, 2004 | 10:05 AM
goodhead's Avatar
Old Dec 22, 2004 | 12:10 PM
Irish's Avatar
This is a democracy
serioulsy dude.......
Old Dec 22, 2004 | 12:43 PM
Thahman's Avatar
Yeh, tint can definitely be a pain in the ***. :-P
Old Dec 22, 2004 | 03:54 PM
maximka's Avatar
it took me all day to take mine off! but the defrost lines are safe!
Old Dec 23, 2004 | 03:56 PM
Fireman Ron's Avatar
Window tinting removal.
I did the same thing. I tried 93% rubbing ahcohol and a wash cloth. Keep the cloth very moist and then the "stuff" will come off in a jiffy. You will have to keep folding the wash cloth because it will become gunky from the glue. And you will need more than one wash cloth. But the glue comes off very fast.
Old Dec 23, 2004 | 09:25 PM
goodhead's Avatar
with the steamer it took 25 min to do both rear windows and back window, defrost lines are mint, just apply stream to an area for about 30-45 sec and you will see it start to peel off on its own and taking the residue with it so you dont have to scrap it, steamers are like $25-$30, and they are great cause u never have to iron your cloth again either!!!! if anyone else STILL gonna use razorblade/paint thinner/whatever else then i give up
Old Dec 24, 2004 | 05:48 PM
sethlondon's Avatar
I just wanted to give a BIG THANKS to those who recommended using a steamer.
I went to WalMart and picked up a $30 steamer and spend about an hour and a half and everything came off really easy (I did the back 5 windows).
No damage to my defroster lines and it saved me $100 by not having to take to the pros to remove.
Old Dec 24, 2004 | 06:44 PM
goodhead's Avatar
someon thats not an idiot!!!
Old Jan 1, 2005 | 11:03 PM
lshi0's Avatar
what kinda steamer should i get, fabric steamer or one looks like iron?
Old Jan 1, 2005 | 11:56 PM
l3ftonm3's Avatar
they have fabric ones, then there is the larger ones that are used for taking down wallpaper
The Frye
Sep 2, 2021 11:03 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
