guage light question
Old Dec 18, 2004 | 02:32 PM
dko683's Avatar
i am planning to switch the bulbs in my guage cluster to leds. i know i have to get 194 (i have a 97 maxima) but i am confused on how many to get. i read some places that i need 5 and other places 6. can someone tell me how many i need? also, i am planning to get the oval wide angle lenses at superlumination. i was wondering if anyone else tried those and if they fit perfectly within the cluster or do i need to sand some something or solder anything. thank you!
Old Dec 18, 2004 | 02:55 PM
MDeezy's Avatar
actually the 97+ dont use 194 but you can convert them to 194s, I believ its #74 that are in the 97+ not sure.
everything should be plug and play assuming you get the right led for your car, if your going to convert to 194s then thats a different story,
dont know how to convert to 194.
Old Dec 18, 2004 | 03:01 PM
MDeezy's Avatar
found a pic of the back of the guages dont know if it helps but cant hurt. . .
Old Dec 18, 2004 | 03:06 PM
icedogg's Avatar
I have a 97...I only saw 4 bulbs that could be replaced...I could totally be wrong but thats what I remember. They use the wedges bulbs, same as the ones in the couresty lights in the front driver and passenger doors...so I am pretty sure they ARE 194's but I could be wrong...
gl
Old Dec 18, 2004 | 05:31 PM
MDeezy's Avatar
sorry 95-97 Max use the 194, but the 98-99 use 74.
found it in the faqs.
http://forums.maxima.org/showpost.ph...8&postcount=55
Old Dec 18, 2004 | 06:20 PM
l3ftonm3's Avatar
the back of the 97 cluster has 5 blubs, I looked at it yesterday, thats on my car anyhow, and it is 194 bulb. I just recently got rid of my reverse indiglo gauges and opted for this. I picked up 5 of these bulbs they looks like they would be the brightest and spread the light the best on how they are setup.
http://www.superbrightleds.com/produ...wled5-diag.gif
http://www.superbrightleds.com/store.../t10-green.jpg
Old Dec 18, 2004 | 06:45 PM
aznprid972's Avatar
yep.. 95-97 uses #194 bulbs. i just changed mine to xenon white bulbs behind them and they look HOT!!
Old Dec 19, 2004 | 10:18 AM
Igobuk's Avatar
5 bulbs, I used the 5 LED 194 bulb from superbrightleds.com (cheaper than superlumination).
One LED pointed forward and 4 pointing to the sides for all around brightness.
95Maxi
Aug 25, 2015 08:01 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
