95 decided not to start
Old Dec 19, 2004 | 08:32 AM
bredda45
First post to a great forum! Thanks...
Last night my wife was out shopping and pulled in to a service station to fill up. Afterwards, tried to start the car and nothing. Key in the ignition, little click from under the hood, all panel lights, headlights, CD, heater, etc., ran fine. Left all the lights on and nothing dimmed when the key was turned. I ruled out the battery and thought the problem may be the starter. Any suggestions before I have it towed to the dealer?
1995 Maxima GLE
105K miles
Thanks again!
Old Dec 19, 2004 | 08:34 AM
Kevlo911's Avatar
Kevlo for President
Ignition switch or starter. You can replace either. Dealer will charge arm and leg.
Old Dec 19, 2004 | 08:38 AM
yhtan76's Avatar
Must the starter
Old Dec 19, 2004 | 09:29 AM
Julchen's Avatar
Take a long screwdriver and tap the side of the starter solenoid. If it starts, then you have a dirty starter. This is a very common problem with the starters in our maximas, and there have been many threads lately driving this issue home. Do a search with my user name. If this is the problem, then the very cheap solution is just to disassemble the starter, clean and lubricate it.
Good Luck,
Greg
Old Dec 19, 2004 | 09:39 AM
mansurxk's Avatar
he wont be able to use the regular search unless he donated on his first post. use the poor man's search. Itll lead to the same thing, ignition switch or the starter, my guess its the starter since its clicking.
Old Dec 19, 2004 | 09:46 AM
bredda45
Thanks for the advice, folks! I'll try the screwdriver trick and then either tear down and clean or swap out. Looks like AutoZone carries them for around a hundred bucks with the limited lifetime warranty. Tried to do a search but it tells me that it's offline for registered users or something like that.
Thanks again for the help!
Old Dec 19, 2004 | 10:05 AM
mansurxk's Avatar
i would still check if its the battery though.
Old Dec 19, 2004 | 11:16 AM
bradkeet's Avatar
my 96 is also not starting with the same symptoms as the original poster of this thread. is it the same types of thigns to look for??
Old Dec 19, 2004 | 06:14 PM
unixadm's Avatar
Mine did the same thing. I started getting intermittent no crank conditions. A click and nothing else. If I turned the key about 40 times or so, I could eventually get it to start and then it would be okay for a day or maybe 3 weeks. Finally when it let me down at lunch with the guy sfrom work, I had to fix it. It was the starter. I picked up a reman from the local Nissan dealer where I know the parts guy. All worked perfectly again on my 95 SE 5-Speed.
Old Dec 20, 2004 | 06:40 AM
bredda45
It was the starter. Tapped the solenoid and it turned right over. Picked up one from AutoZone and started on it late yesterday. I read somewhere where some guy replaced his in 15 minutes. He must work in a pit crew because you have to remove all the air filter housings/ducts and then try and break the starter attach bolts. It takes at least a 3 foot cheater bar to bust open the 17mm bolt.
Starts just like it's supposed to now.
Thanks again for the assist.
Old Dec 20, 2004 | 05:07 PM
gtmuggs's Avatar
Its the starter mines just did this also last wk
new starter from Advanced Auto parts was about $150 after the core price but lifetime warrenty
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
adamgalazka
Sep 9, 2015 03:39 PM
trungg86
Sep 4, 2015 04:58 AM
