Question about brake fluid ?
Old Apr 21, 2001 | 04:08 PM
Vitaly O.'s Avatar
when I change my brake lines and pads and rotors is it a good idea to change my brake fluid or I dont have a choice I will have to do it and if that is the case what kind should I buy and how much of it will I need ?
I know some people said that you have to flush your brake system what is that all about?
Old Apr 21, 2001 | 04:27 PM
alloutmax's Avatar
what i have read before you don't have too, only reason people add new brake fluid in when they change the rotors and pads is because they have this stuff done at a garage and usually the garage has it in the price or they tell the people they have to chnage it to get a few bucks more out of them.
Old Apr 21, 2001 | 04:28 PM
Vitaly O.'s Avatar
ye but...
what about changing your brake lines too?
Old Apr 21, 2001 | 05:54 PM
VQMaxSE's Avatar
If you are replacing calipers and/or brake lines you will have to change the brake fluid. I recently changed my brake fluid. I believe it is recommended every 2-3 yrs because brake fluid absorbes water. The water causes the fluid to boil at a lower temp which causes air bubles in the lines leading to poor brake performace.
I used ATEGLT “ATE Type 200” (ATE Gold) $10, this brand also comes in a blue color that makes it easier to see when you have completely flushed the lines. You will only need one bottle.
I also purchased some "speed bleeders" (www.speedbleeders.com) approx $30. These are bleeder valves that replace the factory bleeders and allow one person to effectively and easily bleed the brakes. They have a one way value that lets fluid out without letting air in when you pump the brakes to flush the system.
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
