Rough Starts
Old Dec 20, 2004 | 07:17 AM
lokobreed's Avatar
Rough Starts
Hello,
I know there are a few threads about this but I feel this will be a good place to get everything in here that can cause rough starts...
My car is a 95 Nissan Maxima SE and in the summer it started up fine, but now in the cold winter, some times it starts rough and takes a while to catch...
What can cause this (rough starts)?
Can your plugs, could it be the starter, the battery?
Old Dec 20, 2004 | 09:25 AM
MDeezy's Avatar
if its dragging and taking a while to crank it could be your starter they have been known to go out. Sparks are a known cause for hard starts check your sparks, take out a few and look at them and see what color it is that can tell you alot.
Old Dec 20, 2004 | 12:55 PM
Saddles's Avatar
check your grounds and crankshaft sensors, as well as look for any other codes...my problem ended up being a crank shaft position sensor code set off by a loose ground, after replacing sensor i had same problem, the CEL, no start, I cranked it and burnt my starter...replacing starter and fixing ground make it all right
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
trungg86
Sep 4, 2015 04:58 AM
