Removing Drivebelt Help
Old Dec 22, 2004 | 07:18 AM
Oblongshapes's Avatar
My alternator crapped out on me..... I adjusted the tenstioner almost to the point where the socket will no longer even go on it anymore..... i had to use a breakerbar for the last couple of turns cause its so tight.
I still cannot slide this belt off.......
help!
Old Dec 22, 2004 | 07:49 AM
mzmtg's Avatar
Minister of Silly Walks
Did you loosen the nut in the center of the pulley before turning the top of the tensioner?
If not, you probably broke the tensioner turning it so hard.
Old Dec 22, 2004 | 09:24 AM
damn! haynes said nothing of the sort...... great
Old Dec 22, 2004 | 10:15 AM
well i got it tight, so i dont think the tensioner is shot. the bolt placing isnt the same as when i started but the belt is tight enough.....
So I loosen the pulley right below the tensioner then loosen the tensioner?
Old Dec 22, 2004 | 01:07 PM
twiggy144's Avatar
Yep. tha'ts the trick.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
