How to install control arm bushings and sway bar bushings
Old Dec 22, 2004 | 08:11 AM
Kevlo911's Avatar
Kevlo for President
I am pretty much a noob when it comes to working on suspensions. How hard is it to remove the control arms? Are the bolts really tight? How are the front sway bar bushings held in? I know on the control arm the old bushings need to be melted off.
Local shop wants $400 and I don't know who else can install it for me in my area.
Old Dec 22, 2004 | 09:08 AM
Dubbya's Avatar
VK56 Inside
I havent done the control arm bushings, but I have heard if they are really shot they will come out pretty easy. Replacing with the energy suspension set is supposed to be a snap. As for the sway bar, those bushings are easy to replace. Just 2 bolts and a nut to remove.
Dub
Edit
2 bolts and a nut per side.
Old Dec 22, 2004 | 11:26 AM
Dave B's Avatar
Not DAVEB the parts guy
Why are you doing aftermarket control arm bushings? They'll be loud, squeak, and add a lot of NVH. You'll need a press and possibly a torch to get the old ones out and the new ones in. Yes, some of the bolts are on there with 100+ ft/lbs of torque. You'll also need an alignment after it's done.
The sway bar bushings are easy, but you need to get a Chiltons/Haynes/Nissan FSM because you need to know some specfics on how new bushings go on, how to align them (important), and how to torque the bolts. Also, when doing this you need jack the whole front end of the car so that both front tires are off the ground. If you don't do it this way, sway bar will be "loaded" and you'll never get it out of the way to get the old bushings out and the new ones in. You'll need to unbolt the endlinks and then the swaybar attachments on both sides before you can do anything.
Old Dec 22, 2004 | 11:29 AM
Matt93SE's Avatar
STFU n00b!
http://www.4dsc.com/articles/suspens..._bushing.shtml
nearly identical on 4th gens.
plan a full day to do it. have fun.
Old Dec 22, 2004 | 11:41 AM
Kevlo911's Avatar
Kevlo for President
I am using hte Energy suspention control arm bushings and the OEM sway bar bushings.
Old Dec 22, 2004 | 11:48 AM
mzmtg's Avatar
Minister of Silly Walks
Originally Posted by Dave B
They'll be loud
In my experience:
No
, squeak
Never
eh...maybe a tiny, tiny, tiny bit
Old Dec 22, 2004 | 11:59 AM
mzmtg's Avatar
This may help:
http://doug.maxima.org/showpost.php?...10&postcount=3
Old Dec 22, 2004 | 12:19 PM
Dave B's Avatar
After installing control arm bushings on my friends Del Sol, the car was a creaky and squeaky nightmare. Everything was luded good too. Of course this was in the dead of winter. Once the temps got above 70 or so, the car was pretty quiet.
Old Dec 22, 2004 | 12:33 PM
mzmtg's Avatar
I've had mine on since march (approx 10,000 miles) with no issues at all.
Old Dec 22, 2004 | 01:19 PM
Matt93SE's Avatar
STFU n00b!
had ES bushings on my car for over a year with no issues.
Old Dec 22, 2004 | 02:10 PM
Kevlo911's Avatar
Kevlo for President
Will the crowbar mess up the balljoint any?
Old Dec 22, 2004 | 02:42 PM
mzmtg's Avatar
No, you're using it as a wedge to push down on the stud.
Old Dec 22, 2004 | 03:28 PM
Matt93SE's Avatar
STFU n00b!
it won't mess up on the ball joint, but be careful not to damage the boot on the balljoint.
Old Dec 24, 2004 | 05:50 AM
goldmax's Avatar
How hard of a job is it to install new control arms? I don't mind spending the $$ if it will save me hours of aggravation under the car trying to install new bushings and ball joints in the old arms. I've replaced everything else up front and it's still got wander over uneven pavement. I'm at 113K, so I figure the bushings and ball joints are shot. `
Old Dec 24, 2004 | 06:00 AM
Cutler's Avatar
Take the control arm to a machine shop so they can press the new ball joint in
Matt93SE
May 24, 2019 02:58 PM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
jerrod99_se-l
Aug 10, 2015 12:07 AM
