starting problem
Old Dec 22, 2004 | 08:24 PM
zone1982's Avatar
starting problem
i got a problem starting the car when its cold, it cranks but it wont start i gota give it a few tries and then it starts up, when its not cold it starts up fine, any clue what it might be?
Old Dec 22, 2004 | 11:31 PM
f550maranello2's Avatar
i used to have the same problem... couldnt figure it out for a while.. until i changed the intake manifold collector gasket cuz it looked bad and oil soaked... it helped... but do some investigation for urself... like a tune up for starters... oh and by the way if u are running low on gas ( like less then a quarter tank) the car (at least mine and my buddies) doesnt like to start at first... good luck
Old Dec 25, 2004 | 06:25 PM
Maximized Jiggs's Avatar
Help Help.
Old Dec 25, 2004 | 07:30 PM
njmaxseltd's Avatar
Check the resistance of the engine coolant temp sensor. There is a table in the shop manual that gives proper resistance readings for given temperatures. Make sure your throttle body is clean, and check the adjustment and operation of the cold idle plunger and linkage. The Haynes manual has a good write up on how to check and adjust the cold idle linkage as well as the temperature/resistance table for the engine coolant temp sensor.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
