painting wheels
Old Dec 24, 2004 | 12:50 PM
jtm087's Avatar
painting wheels
in the how to's section on painting wheels, the instructions say to strip the factory paint off and sand it down.....what if you dont will there be a problem with the paint staying of fading?????
Old Dec 24, 2004 | 02:19 PM
206maxima's Avatar
its not gonna hold on to the rim. its gonna peel off in time. so you should do it. its alot of work but its worth it. goodluck!
Old Dec 24, 2004 | 02:34 PM
sterlingmaxima's Avatar
um jsutter did it by sanding it so the paint will adhere i would do that instead of striping
Old Dec 24, 2004 | 03:43 PM
Ant96GLE's Avatar
Your all wrong...
You need paint stripper aka aircraft paint remover. That will remove all the paint. Then you can paint over and it will stick, it will be fine.
Old Dec 24, 2004 | 04:03 PM
Ladzio's Avatar
Originally Posted by Ant96GLE
Your all wrong...
yea what he says, you need to degrease the surface also before you paint for better results.
Old Dec 24, 2004 | 04:05 PM
hollaatchaboi's Avatar
i've seen some where the rim was just scuffed with sand paper and the paint adhered fine. And it has held up.
Old Dec 24, 2004 | 04:35 PM
aspec0002's Avatar
ive done quite a few sets, on some i just used a dishwashing pad and cleaned them with the green side not too much pressure though, never had any rims chip unless they rub a curb...
Old Dec 24, 2004 | 07:27 PM
I want to do this to my current rims, however, I want to keep certain parts silver in the design. I'd lose this and the machined look if i used the stripper. Therefore, i'm going to try the scuffing method.
Old Dec 25, 2004 | 06:33 AM
RA030726's Avatar
I'm nutty for Nissans
you really dont need to paint the bare metal unless you are powder coating. There is absolutely no point in stripping the wheels. I have done it both ways and they come out the same, or better if you dont strip them. Think of the original stuff (paint on 97-99, clear on 95-96) as a primer. Why waste time and money when you can clean them, scuff them, and repaint them. I have used a pressure washer on them and the paint wont come off. if thats not abuse i dont know what is.
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
