Installed a mod today
Old 12-25-2004, 12:59 PM
Custom User Title
Nismo3112's Avatar
I have officially joined the 00VI club:
Good Hood clearance
4th Gen TB
Good Injector Clearance
To make it fit, I had to grind down 2 of the coil holders in the back like StephenMax did, plus I had to grind off a little bit from 2 of the rear coils. I still have to find a place to mount the IACV, and I have to buy an "L" shaped elbow for the PCV valve, connect various hoses, hook up the VI vacuum system, and i'm good to go.
-Terry
Nismo3112 is offline
Old 12-25-2004, 03:19 PM
Gen8888's Avatar
Wow great job. I would love to see that car some day...
Gen8888 is offline
Old 12-25-2004, 03:22 PM
Zack342's Avatar
very nice...
Zack342 is offline
Old 12-25-2004, 03:38 PM
matty's Avatar
Im ordering mine in about a week...
Few questions...
Does the Car run without the IACV hooked up ? Did you just lay all the connectors there and thats is ??
Did you fab the plate at the throttle body or whered you buy that ??
how about the EGR guide tube in the back of the manifold, what happens witht hat >? and the coolant lines ??
You used a 4th Gen Lower manifold and drilled or did you use a 5th lower, and injectors, and rail ??
I need learn alot because im gonna be doin this soon
-matt
matty is offline
Old 12-25-2004, 04:05 PM
Custom User Title
Nismo3112's Avatar
IACV: I made a plate with a barb fitting. I can mount this anywhere in the engine bay, it will be connected to a hose that will be connected to the adapter plate via another barb fitting:
Adapter Plate: I made it out of 2 pieces of aluminum. I wanted the TB to sit upright (oppsed to sitting sort of turned) I had to use two plates so none of the holes would interfere with each other.
EGR: No more EGR for me. Removed the entire system. It was disconnected for about 6 months anyway. The coolant lines just run a hose connecting them to each other.
I am using the 4th gen lower, injectors, and fuel rail. The two inner holes on the 00VI I had to bore out a little bit, and the 2 sides I had to drill new holes.
Old 12-25-2004, 04:28 PM
matty's Avatar
Howd you get rid of that ??
Im waitin for stephan max's entire write up so I can peice this together... I still may not do this
-matt
matty is offline
Old 12-25-2004, 04:31 PM
Custom User Title
Nismo3112's Avatar
Just take the valve and pipes off and plug off the the pipe going 2 the exhaust manifold. It takes away alot of the clutter in there and makes the engine bay look a little cleaner.
Old 12-25-2004, 05:04 PM
BigLou93SE's Avatar
I might as well swallow my pride here, and ask: what is the "egr" system. What does it do? While I'm at it, IACV?
BigLou93SE is offline
Old 12-25-2004, 05:10 PM
Custom User Title
Nismo3112's Avatar
IACV: idle air control valve lets air get in the engine while TB is closed.
EGR: exhaust gas recirculation, basically rerouting exhaust gases back into the intake manifold.
Old 12-25-2004, 05:16 PM
MrGone's Avatar
MrGone is offline
Old 12-25-2004, 05:17 PM
BigLou93SE's Avatar
thanks, I had a general idea about the IACV, but was clueless about the EGR...why are you able to run your car without the EGR system -- why is it not vital? Is it necessary on regular VQ30's?
Old 12-25-2004, 05:21 PM
Maxima.Org Bishes
MAXDADDY98's Avatar
How much does that thing cost?
MAXDADDY98 is offline
Custom User Title
Nismo3112's Avatar
It isn't vital for the car to run, I have had no problems running the car with it disconnected, it makes the exhaust gases cleaner, but for the sake of easier installation and a cleaner intake manifold, I removed it.
Old 12-25-2004, 05:24 PM
Custom User Title
Nismo3112's Avatar
I bought it off a .org member for $130 shipped. Wayyyyyyyy cheaper than the MEVI, and proven to provide better gains.
Old 12-25-2004, 05:31 PM
Maxima.Org Bishes
MAXDADDY98's Avatar
Hey I want one. Where do you get one from? or who is sellin one for cheap
Old 12-25-2004, 05:35 PM
Custom User Title
Nismo3112's Avatar
2000 - 2001 Maxima/I30
For Sale section or car-part.com
Keep in mind this is no bolt on. Some modification required
Old 12-25-2004, 05:57 PM
lxl - MaX's Avatar
so how much am i looking to spend if i wanted to do do this myself?
lxl - MaX is offline
Old 12-25-2004, 06:12 PM
Custom User Title
Nismo3112's Avatar
$130 for the VI
$10 aluminum to make plates/adapters
$10 various bolts/screws
$50 RPM switch
$3 TB cleaner
$203 so far... Pretty good considering the gains provided.
Old 12-25-2004, 07:48 PM
madmax96's Avatar
can you go with the fuel rail and injecters from the 00 or 01 to make it easyer or would it be harder to do that
madmax96 is offline
Old 12-25-2004, 08:10 PM
my99maxisnice's Avatar
There has got to be a sticky on this, like there was on the MEVI. So every single thread doesn't have the same questions asked.
my99maxisnice is offline
Old 12-25-2004, 08:12 PM
I'm nutty for Nissans
JSutter's Avatar
no egr codes?
JSutter is offline
Old 12-25-2004, 08:13 PM
Boosted Panda
Flava_24/7's Avatar
$130 for the VI
$50 RPM switch
$3 TB cleaner
Dont you still need a modded ECU with the raised rev limiter?
Flava_24/7 is offline
Old 12-25-2004, 08:36 PM
Always sunny in philly
Nismotic's Avatar
fuggin' nice.
Nismotic is offline
Old 12-25-2004, 08:51 PM
SDot82's Avatar
Thats what I was wondering, if you bought the upper and lower manifold, injectors, fuel rail, and the 5th gen throttle body. I know it would be more expensive but would it be easier to install.
SDot82 is offline
Old 12-25-2004, 08:59 PM
craig10114's Avatar
yea there needs to be a sticky on this with all new information full and partial write up's untill a bullet proof write up with detailed pictures becomes available....i have a feeling this mod along with 3.5 bottem ends is going to become as popular and frequent as the Y pipe
craig10114 is offline
Old 12-25-2004, 09:10 PM
Custom User Title
Nismo3112's Avatar
It's not needed, it will only add to the performance. But I do want
no egr codes?
I had the system disconnected for half a year now, and no codes. The only code that I get is for the transmission computer, & thats because I did the swap
If you can get the 00 lower, injectors, and rails, then go with that. The installation will be alot easier and you won't have to grind anything. But I stuck with the 4th gen stuff. All that was done to make the 4th gen lower work was flip it around, reinstall it, and on the VI, bore out 2 holes, and drill 2 new holes. Some guys that went with the 00 injectors required some fuel tuning also.
Old 12-26-2004, 02:46 AM
aznprid972's Avatar
proven to provide better gains than the MEVI ?... just curious.. better gains as in no loss in bottom end torque or better gains throughout the whole rpm band?
aznprid972 is offline
Old 12-26-2004, 07:33 AM
Custom User Title
Nismo3112's Avatar
No low end - mid range loss like the MEVI. There are a few dynos in the all motor forum.
Old 12-26-2004, 11:37 AM
matty's Avatar
What did you need to bore out on the 5th gen intake pelenium ?
Im wondering if this is actaully worth it conserding the amount of the stuff that needs to be changed...where are you goign to mount the IACV ??
-matt
matty is offline
Old 12-26-2004, 03:13 PM
Jedi Knight
nupe500's Avatar
-matt
.......read all threads about this mod and gains are impressive for the price, but wondering if all modifications done to the IACV and EGR won't come and bite me in the as S
nupe500 is offline
Old 12-26-2004, 03:56 PM
Custom User Title
Nismo3112's Avatar
Well I got everything installed and took it out for a spin... OMFG top end pulls NICELY... I can't comment on the low-mid range because I dont have my RPM switch yet, so I left the VI open.
But it keeps stalling at red lights.... So I carefully drive home, pop the hood, idles a little better, I take the IACV and move it back and forth and it starts to idle like normal.
This is leading me to think that when the hood is closed the IACV hose is getting pinched (sort of like a kink in a garden hose)..... So I have to get new hoses and a new elbow, do some idle adjustments, and i'm good to go.
I also had a fuel leak when I started the car... I completely forgot to tighten down the fuel rail
The car felt a little bouncy while on my test drive... Forgot to tighten the upper strut nuts
It's been a long day.
Matty: The 2 center front holes on the 00VI is what needed to be bored out. They look like copper or brass sleeves.
One thing I can't figure out is the vacuum plunger...... I was curious to see what would happen when I connected a vacuum source to it. To my surprise even at idle the the plunger was open.. I then connected a 12V source to the solenoid and nothing happens. Looks like all I need is a standalone MAP switch...
Old 12-26-2004, 04:39 PM
Boosted Panda
Flava_24/7's Avatar
(Nismo3112) It's not needed, it will only add to the performance. But I do want
Without the ECU how do you continue to build power past the stock fuel cutoff?
With the others who have done this, didnt they all have modded ecu's?
Without the extended rev limiter, how far up does it continue to build power?
Old 12-26-2004, 05:35 PM
I need a truck
Conrad283's Avatar
That's a pretty sweet install job. Kudos.
Conrad283 is offline
Old 12-26-2004, 05:50 PM
DR-Max's Avatar
The EGR system is an emissions device that reduces emissions by recirculating some of the exhaust gas back into the intake system. I wouldn't be surprised if your car fails your next smog check. It's interesting how it was the other way around for me. For a whole year my car had been plagued by EGR related ECU codes and would not pass smog even if my life depended on it until I replaced the EGRC control solenoid valve. But before I replaced that I had spent hours checking the entire system for failing components and other related components. I even replaced all vacuum tubes in the system. I wish you luck on your next smog check! If you already got this covered, I'd like to know how. It's almost useless having a MEVI here in So-Cal, traffic is so congested that its rare that you get to really open her up in the highways and really see the MEVI power in action long enough.
DR-Max is offline
Old 12-26-2004, 06:34 PM
Custom User Title
Nismo3112's Avatar
I still have the stock fuel cutoff, stock redline. With the stock manifold, peak power is at around 5400 - 5500 rpm, and after that the engine chokes, whereas the 00VI holds power until about redline (6500-6600) , instead of dropping off.
2DaMax: There are no required smog tests in my city. Or else my car would fail terribly
Old 12-26-2004, 06:57 PM
Boosted Panda
Flava_24/7's Avatar
Thats really good for no ecu upgrade. nice steady build of power to a decently high rpm.
Old 12-27-2004, 09:30 AM
DR-Max's Avatar
Lucky you!
DR-Max is offline
JRod28
12-29-2023 09:56 PM
Maxima_Joe
08-27-2015 12:01 AM
Trin1j23
08-12-2015 08:31 PM
Quick Reply: Installed a mod today
