grease antenna?
Yeah, silicone in a spray can. I used Lithium in a spray can on my 93 Max and that was good too. I was looking for something that dried after application, and both of them did that. Otherwise, stuff like WD-40 will gunk up.
Carnal, good to see u home.
Jae
Jae
You really don't want lube on your antenna, just keep the metal shaft clean using WD-40 and a rag. The plastic spline & gear that unwinds and winds back up inside the shaft is enclosed in the motor assembly and loaded up with white grease. Thats the part that fails causing your antenna to stop working. If anything you might open up that unit to clean and regrease it. You have to take the antenna assembly out of the trunk to work on it. Make sure you don't loose any parts when you take the cover off.
Jae
Jae
Violator
Sep 9, 2015 10:14 AM
