CEL Light problem
Old Dec 25, 2004 | 02:18 PM
konak85's Avatar
CEL Light problem
Just bought my car a few months back. The problem is that when I turn the key in the ignition to "on", without starting engine, the Check engine light doesn't come on, all other lights do. Its supposed to right? Where can i start looking for the problem. Bulb? Fuse?
Old Dec 25, 2004 | 02:56 PM
exit10's Avatar
this was the same issue with me. it is the bulb in my case. i followed the simple write up on how to open up the dash in the HOW TO's. then once the dash was open i swapped the DOOR AJAR bulb with the CEL bulb. the bulb is in this little brown harness that you just twist out. in my case i bought the wrong bulb from autozone so i just swapped it.
good luck pm me for help
Old Dec 25, 2004 | 02:58 PM
exit10's Avatar
also i forgot to add once the dash is open it says which socket belongs to which function aka door ajar, gas light, brake light, cel light. its very easy
Old Dec 25, 2004 | 03:01 PM
MDeezy's Avatar
I'd try reseting the ecu and see if you definately dont see the light, maybe they check for codes but didnt reset, maybe to hide the check light from buyers.
Cant be too careful now-a-days
Old Dec 25, 2004 | 03:28 PM
konak85's Avatar
thanx for ideas. any other ideas anyone.
Old Dec 25, 2004 | 03:56 PM
exit10's Avatar
trust me your bulb was taken out. now go take apart your dash and stop wasting time. its too simple
Old Dec 26, 2004 | 05:49 AM
konak85's Avatar
thanks man. i'll try it
tsi6001
Oct 3, 2022 10:23 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
