Trouble with car
Old Apr 22, 2001 | 06:08 PM
MACKAVELLI's Avatar
i havea 98 maxima with 20k miles on it,i did not drive it oneday and the next day i went to start it and it was hard for me to start my engine, i heard clicking sounds, so i went to start it again and finally it started roughly, has anyone had this problem, if so can someone tell me what might be the problem?
Old Apr 22, 2001 | 06:12 PM
BrianV's Avatar
Were you low on gas? Sometimes when you're low on gas your fuel lines aren't filled with solid fuel, but more of an air/fuel mixture. Also, if you were parked on a hill for an extended period of time the fuel runs to one side of the tank and it's hard for the fuel pump to pump fuel.
Your starter could be going bad, but highly unlikely.
Old Apr 22, 2001 | 06:35 PM
Daniel B. Martin's Avatar
Originally posted by BrianV
... Sometimes when you're low on gas your fuel lines aren't filled with solid fuel, but more of an air/fuel mixture. ...
I respectfully disagree. The fuel lines should always be full of pressurized gasoline, regardless of the amount of fuel in the tank. If this is not the case, residual fuel pressure has been lost. Possible causes include ...
- an external leak anywhere in the fuel loop
- a leaky fuel pump check valve
- a bad fuel pressure regulator
- one or more fuel injectors which sticks open
Old Apr 22, 2001 | 06:42 PM
MACKAVELLI's Avatar
yeah it runs now okay, the sound was comming from the engine while i was turning to start it (clicking sound) , i had a half of tank of fuel left, im thinking that in the morning i turned on the engine and turned it off, not letting the engine burn the gas fully, but im not sure, any one else have any opinion on what it might be. its a 98 maxima i only have 20k miles on it and i take care if it, i change the oil every 3 months or 3k miles. damn ima take it to the shop on friday, but if anyone has any opinions, please let me know what it might be, so i can ask the mechanic to check it out, thanks alot guys
Old Apr 22, 2001 | 06:46 PM
Chunger's Avatar
My other car is a Hybrid
When it did turn over...was it slow... sounds like a low battery or poor connection.
Old Apr 22, 2001 | 07:02 PM
MACKAVELLI's Avatar
yea something like that, but it wasnt. i highly doubt that.thanks anyways
Originally posted by MACKAVELLI
yeah it runs now okay, the sound was comming from the engine while i was turning to start it (clicking sound) ...
This is a symptom of a discharged battery or loose/dirty cable connections at the battery, the engine block ground, or the starter motor.
Old Apr 22, 2001 | 09:08 PM
MaxedOut97SE
Who cares just take it to the dealer, it's under warranty!
Old Apr 23, 2001 | 04:44 AM
A note of caution...
1) Depending on the original delivery date, the 3 year / 36K mile warranty may have aged out on a '98 Maxima.
2) Charging a discharged battery will not be a no-cost warranty repair unless a defect is found in the battery or charging system. A discharged battery is a customer problem, just the same as an empty gas tank.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
