1998 i30 and throttle shock
Old Dec 27, 2004 | 08:16 PM
r5clp's Avatar
Just bought 1998 i30 and found that it shifts 3-4-3-4 and seems that does not know what gear to use when I drive off ramp on about 40 mph.
Did a search and found TSB 98-064a "98-064A JUN 99 ECM - On/Off Throttle Shock" here
My car is not 8 years old yet and has 60kmi, is there any chance to replace ECU under Federal Emission Warranty? Any "right" words to say to the dealer? I bought it from private party...
Any advice is really appreciated!
Old Dec 28, 2004 | 06:24 AM
MrEous's Avatar
^ Jeff™
iirc, call the dealership and have them run your VIN for any TSBs. I believe TSBs last the life of a car until it is fixed per what the TSB says.
Old Dec 28, 2004 | 07:27 AM
I30tMikeD's Avatar
What else have you found besides "throttle shock" to describe your problem. Is there more information about that particular TSB?
Old Dec 28, 2004 | 09:42 AM
r5clp's Avatar
Item 2 in this post describes my problem exactly
Old Dec 28, 2004 | 10:02 AM
Kevlo911's Avatar
Kevlo for President
Turn off OD and see if it still happens.
Old Dec 28, 2004 | 10:09 AM
unixadm's Avatar
A TSB is only fixed for free under the bumper to bumper warranty. A recall lasts the life of the vehicle. If there is updated code for the ECU, you can typically have the dealer flash that for a nominal fee.
Old Dec 28, 2004 | 10:17 AM
r5clp's Avatar
You mean that the dealer can upgrade a firmware?
Old Dec 28, 2004 | 10:18 AM
I30tMikeD's Avatar
I have never owned or worked on an auto maxima/I30 but isn't there a seperate transmission control unit? The main ECU does not control shifting does it?
Old Dec 28, 2004 | 10:23 AM
r5clp's Avatar
I am out of that warranty. I'll try to re-phrase the question.
TSB says that ECU needs to be replaced. Dealer will try to charge me, because I am out of bumper to bumper warranty. But ECU is covered by Federal Emission Waranty. Is there any chance to pay only for labor, but for ECU unit charge Nissan or Federal Government or whoever it is?
Thanks!
Old Dec 28, 2004 | 10:25 AM
r5clp's Avatar
TSB says it does. I'll post the link to TSB from home, can't find it right away
Old Dec 28, 2004 | 10:29 AM
r5clp's Avatar
I could not recreate the problem with O/D off. Will try again. But the point is, if there is a chance to replace the ECU for free then I will do replace it.
Old Dec 28, 2004 | 10:37 AM
I30tMikeD's Avatar
If it does and replacing the ECU is indeed what needs to be done, then get a used one from www.car-parts.com There will be alot under $100. You need to match up the part number on the ECU with the one your buying.
Old Dec 28, 2004 | 10:39 AM
I30tMikeD's Avatar
Good luck with that. They will do everything not to cover it. A new ECU from a dealer is over $1000.
Old Dec 28, 2004 | 11:18 AM
r5clp's Avatar
TSB says it does.
Here it is:
TSB 98-064
Old Dec 29, 2004 | 07:25 AM
flthere's Avatar
I'm sorry but I didn't understand what the problem is, even after reading the TSB ... can someone explain this in a layman's way? Thanks a lot.
I too have a 98 I30 and I haven't noticed the continuous shifts from/to 3/4 in the speed range. If I give more gas, it shifts from 4th to 3rd and as I reduce the throttle, it goes back to 4th after reaching sufficient speed.
Old Dec 29, 2004 | 07:42 AM
Kevlo911's Avatar
Kevlo for President
It says somewhere in the owners manual, you you don't like it shifting from 3-4,4-3 keep od off. Your MPG will suffer a little too.
Old Dec 29, 2004 | 07:53 AM
I30tMikeD's Avatar
Sounds like you don't have problem then
Old Dec 29, 2004 | 08:14 AM
flthere's Avatar
thanks Mike for the clarification ...
James92SE
142
Jan 2, 2024 09:23 AM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
