Need help fast on engine mount
I am about to purchase a front motor mount for my 95 SE 5-speed but the seller listed the mount as automatic and said it's good for manual tranny as well. Could someone confirm that?
Thank you very much and waiting online.
Thanks. Reason I asked is that I was looking at some other online stores that sells both and the automatic one is a $40 more expensive(maybe extra sensor or sth., I don't know). Well, as long as the automatic engine mount works in a 5-speed model, I am going for it.
Errr...I did a search online as well and I may have been wrong. I don't know. Hold off till someone else chimes in here.
The motor mount for the a/t was much more expensive and had a different part # than the m/t.
Sorry about the misinformation!
Originally Posted by nismology
The motor mounts are not the same with autos and manuals. The auto mounts are liquid-filled and are electronically controlled by the ECU
Originally Posted by Y-MAX
If I do put a auto engine mount into my 5 speed SE, would it be better, worse or equal to the correct replacement?
Someone please help...
Nismology,
So does the auto engine mount has a sensor or connector with it as it's controlled by ECU? And if the auto engine mount is filled with liquid, does it work differently than our manual engine mount? Just curious.
If there is a sensor then you wouldn't hook it up to anything. You don't have anything to worry about. As Mzmtg said, you wouldn't notice a difference between the 2...besides the price.
6spd4dsc
Mar 4, 2016 05:19 PM
ballerchris510
Sep 11, 2015 05:29 PM
