need quick help: what is how much to torque the two starter bolts?
the big bolt was on tight as hell when i took the starter off. can somebody tell me what the torque specs for the two bolts are? thanks much
Just for the record, according to the '98 Nissan service manual page EL-27 the two rear bolts (one long, one much shorter) has the longer bolt at a torque spec of 57-72 ft-lb. The
short bolt is 22-30 ft-lb. I had to replace my starter at ~42k mi., started squealing.
Originally Posted by 90EightSE
'98. I had it replaced by a shop and it was around $300 parts & labor if I recall. Have to check my records for the exact amount.
I replaced mine in like 20 minutes... it only has 2 bolts and the connector on the back... access is very easy, all you need to to is take off the stock intake
litch
123
01-04-2024 07:01 PM
RealityCheck
10-02-2015 06:34 PM
maxima297
09-30-2015 03:32 PM
