how 2 tell if am i droped or not???
when i bought my car it came with 4 tokio blue shocks with springs. i never knew what kind or springs they are but they are red. i allways thought my maxed looked low but now i am having second thoughts. also recently i put 2 kyb gr2s up front with the same springs i originally had but now the front end seems higher then it used to. can this be?
is there a way to measure the gap between the wheel and the wheel well on a 96'?
or is a simple solution 2 buy new springs.... ANY SUGGESTIONS on a particular spring u prefer?
Stock springs should be right about 4 fingers, check it out. If they're red they should be aftermarket springs, stocks are black, unless the guy painted them which I doubt very highly. Plus the aftermarkets usually have a lot more coils on top.
Originally Posted by ManualMaxima
dropzone is slammed though or 2 inches.....you could tell if he was down 2 inched in the sig. I have painted red H&R's
SInce when are dropzones slammed?
Ive never seen a max with dropzone springs look slammed unless they were cut.
Coilover yes, but not just lowering springs.
My Sprints look lower then dropzones.
madmax97
Sep 19, 2002 01:04 PM
