30, 32 or 35 psi?
Old Dec 30, 2004 | 04:36 AM
tian's Avatar
30, 32 or 35 psi?
i found the tire placard says 29 psi. dealer told me 30 psi. and heard lots people say 32 or 35. which is correct?
does different tire require different pressure?
is it necessary to have higher pressure in the winter? how much?
do you use any tool to add air by yourself, instead of going to the gas station (which i don't feel convenient and reliable)?
Old Dec 30, 2004 | 05:17 AM
laylow1988's Avatar
DURING THE WINTER UR TIRE TEND TO LOSE AIR FOR SOME REASON I USE 35 IN WINTER TIME AND 30-35 THE REST OF THE YEAR
Old Dec 30, 2004 | 05:22 AM
mzmtg's Avatar
Minister of Silly Walks
You don't "lose air" in the winter. As the air gets colder it contracts, lowering the pressure in your tires. The rule of thumb is that you lose or gain 1psi for each 10 degree (F) change in outside air temp.
I run 35psi in the front and 33 in the back. I've just found that is what I like best. It's trial and error.
Old Dec 30, 2004 | 05:58 AM
laylow1988's Avatar
[QUOTE=mzmtg]You don't "lose air" in the winter. As the air gets colder it contracts, lowering the pressure in your tires.
I THOUGHT THAT WAS WHAT I WAS IMPLYING BUT ANY WAY
Old Dec 30, 2004 | 01:31 PM
drewm's Avatar
http://maxmods.dyndns.org/index.php?TirePressure
Old Dec 30, 2004 | 04:46 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
32psi all around works for me
Old Dec 30, 2004 | 05:11 PM
MDeezy's Avatar
The factory number were printed under the arm rest, just flip it up and read the white lable.
33 front 32 rear, I run a little more in front and back.
Old Dec 30, 2004 | 07:15 PM
MilesA's Avatar
You can buy a small portable 12-volt air compressor for inflating tires, air mattresses, basketballs, etc. Very convenient and not expensive. Get a good quality tire gauge. Check your tire pressures every week or two.
The "right" tire pressure does depend on your tires and the type of driving you are doing. 32-34f/30-32r works for me.
Old Dec 30, 2004 | 07:24 PM
Nismotic's Avatar
Always sunny in philly
I just realized that my rear tires were losing a lot of pressure. It actually went down to 20 psi :
Old Dec 30, 2004 | 10:09 PM
Broaner's Avatar
2060lbs and falling...
44PSI here... You need to ask yourself what you want in the car. Comfort or handling/gas mileage?
Old Dec 30, 2004 | 10:34 PM
maximariceboi's Avatar
yea, just flip on the armrest and the sticker will tell you. mine says 32 front 29 rear...but what kind of tires are on now?
Old Dec 30, 2004 | 11:16 PM
VIP Maxima
LOOL i read the title and i was like, "this fool is fookin nutz, who runs that much boost?" then i quickly realized that u were talkin about tire pressure.
personally i like 35 PSI the best and thats what i run all around.
aw11power
Oct 10, 2021 04:57 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
cruce91
Sep 20, 2015 10:23 AM
Maxboy23
Sep 8, 2015 06:53 PM
Nismo87SE
Jan 14, 2002 02:56 AM
