Replacing bulb for stock fog lamp
Old Dec 31, 2004 | 07:01 AM
eric96se's Avatar
I searched the "how to" sections and came up with nothing. I got under the car to try and remove it but I couldn't figure out how to get the bulb out. Anyone have any links on how to remove the fog lamp bulb?
Old Dec 31, 2004 | 07:23 AM
Greg1997se's Avatar
replacing bulb
all you have to do is pull out the black cover to the left or right of the light. It is a plastic type screw that just clicks in and out, you will not break it. Then there is a screw under there which you unscrew and then replace the bulb. It's that easy.
Old Dec 31, 2004 | 12:24 PM
4DRSpeed's Avatar
Project Ruby......
A screw to get to the bulb? Say what??
Jack the car up, remove the one screw for the underbody cover that protects the motor from water and debris. Pull the cover back, you'll then see a black cap with wires running out of it. Turn it to the left and pull it off.
Then there will be a copper bracket running in front of the housing. I believe you push in then pull down so it unhooks from the catch and then pull it out. Then just take the bulb out.
Old Dec 31, 2004 | 01:52 PM
ScarfaceTHX's Avatar
Evidently it's a little easier to change them on a '97-'99.
Old Dec 31, 2004 | 02:33 PM
Irish's Avatar
This is a democracy
1 plastic screw, 2 on the bracket and your done...
03VQMAX
Oct 2, 2016 09:36 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
