Burnt headlight harness
Old Dec 31, 2004 | 08:04 PM
hollaatchaboi's Avatar
I had upgraded my bulbs a couple of months ago and recently one of the harnesses burnt up. Now I need to upgrade the harness. If i get the harness that has a new socket and 12 gauge wiring, I can connect directly to stock wires...correct?
I read the 9004 to 9007 conversion how- to. Yet, I'm still a little confused. If I wanted to, could i get the harness with the three 12 gauge wires, switch the low and ground wires and thats it?
Any suggestions would help. Thanx
Old Dec 31, 2004 | 11:08 PM
bump.......
Old Jan 1, 2005 | 10:52 AM
|Bijan|'s Avatar
UCF Lexus
"Matrix" sells an upgraded wire harness...I had it on my 3rd gen. It does have better light output.
I have the silverstars in my headlights, and PIAA crystal ion fogs.....I couldnt be happier. Very great output.
Old Jan 1, 2005 | 11:26 AM
RA030726's Avatar
I'm nutty for Nissans
I dont know first hand what melts first; the connector or the thin wires. I personally wouldnt buy new pig tails and connect them straight to the stock wires while staying with over watt bulbs. It just doesnt make sence. I found some really nice pig tails at Advanced Auto. The wires are thick, well insulated and the plastic connector is rather nice. If you wanna simply spice into the stock wires with a new pig tail then STAY with STOCK wattage bulbs.
Old Jan 1, 2005 | 12:52 PM
ManualMaxima's Avatar
5th Gen till she dies!
ya i had matrix headlgiht harnesses on my car before my kit, and i had sone 80 watts in there. the harnessed held up real good. I made an extra ground on them. Light was alot better and thye were liek $13 for the pair i think.
Old Jan 1, 2005 | 01:56 PM
Well, the connector is what melted in my car. Why wouldn't it work if i splice into the stock wires? then the connector would last.
Old Jan 1, 2005 | 01:59 PM
Where did you get the Matrix harness and did you splice into stock wiring? where did you ground to?
Old Jan 1, 2005 | 07:51 PM
but will it work if i splice into stock wiring?
Old Jan 1, 2005 | 07:52 PM
|Bijan|'s Avatar
UCF Lexus
it plugs into your stock connector. It will come with 2 relays, 2 grounds, power, and singal wires.
Old Jan 1, 2005 | 08:20 PM
Since my headlight harness isn't a true upgrade, just basically 12" guage wires connected straight into the oem wires, I did the re-ground mod that kevlo911 did to his maxima many moons ago and many others did it with very good results. If interested, read this thread. What an improvement....I was able to see more of the road now!!! The beams are more intense!!! I had to readjust the headlights again so I don't blind oncoming traffic. I'm pretty happy with the way this project turned out.
Quote by 2damax
I found this in the how to's. This is what I am talking about, just looking for feedback from others if it will work. I have too many things feeding off my battery and I don't want to add more (this is why i don't want to get the other harness you have mentioned.)
Old Jan 1, 2005 | 08:57 PM
RA030726's Avatar
it will work. what bulbs are you going to run?
Old Jan 1, 2005 | 09:15 PM
forgot the name, but they are 9004 80w/100w bulbs
Old Jan 1, 2005 | 09:31 PM
RA030726's Avatar
they will work tho iim not sure how the stock wires will like it. my car had over watts when i bought it. i threw them away quick however.
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
