O2 Sensor Brands
hmmmm plug and play seems like it is the way to go...
so from what ive read from the haynes manual...just take out the old with a special socket, disconnect the wiring...put in the new one and reset the ECU and should be good to go??
Originally Posted by maxtuner96
How would I know if the O2 sensor is bad? How much do the sensors cost?, and how do you know which one to replace?
They are around 70 bucks to replace
I bought the Walkers http://forums.maxima.org/showthread.php?t=289189
Originally Posted by caudio51
Your check engine light will come on...I then did a self diagnosis and it gives you a couple of codes....find out what the codes mean and then you know which sensor it is.
I'll have to get around to changing an 02 Sensor as well. I've had a check engine light for a month or so because of it. I cleared it a couple of times, just so I don't have to look at the light...but I guess I'll eventually fix it the next time I go home.
is it possible to change without jacking up the car?? ie just crawling underneath it??
I got my denso's From OEM www.oxygensensors.com . I know they cost a little more but i rather pay the extra money for the name and the quality. I don't know much about the Bosch and Walker. I know Bosch Plugs are crappy so i didn't they they would make good O2 sesnors. I just get the OEM DENSO. PLugged it and i works like a a charm.
