tire go bad to fast
Old Jan 4, 2005 | 02:43 AM
precision727's Avatar
tire go bad to fast
can any help me with my problem. my96 maxima is drop with Tokico shock and dropZone spring on a set of 18x7.5 rim. Im having to buy new set of tire every 3 to 4 month. A tire store where i get my tire from change out my factory camber bolt and replace it with diffiernt camber bolt. but it still the same. my car still pull to the right. the steerling wheel start to shack when I drive between 65mph to 70mph anything above or below that speed it dont shack.also when I small dip or when i change lane and hit the center divider it feel like you hit a brick on flat tire. I keep having to take the car to the repair store to get my tire bal and alignment. if any one can help me out ? Do I need other part to fix this problem? I spend around $800 on Z rate tire every 3 to 4 month. If any one can help thank
Old Jan 4, 2005 | 04:06 AM
happyricefob's Avatar
V^___^V
1. swap out your dropzone springs to tein s-tech or sprint springs, cuz dropzone springs sag in the rear and it sux.
2. if you are running tokico HP shocks, switch it out to either KYB AGX or tokico illuminas shocks, cuz tokico HP shocks will not handle anything lower than 1.5" drop...eventually the HP shocks will blow out.
3. check your tire pressure. i suggest running 33psi for 18" tires.
4. balance your tires
Old Jan 4, 2005 | 05:48 AM
mzmtg's Avatar
Minister of Silly Walks
If you keep going back to the same shop and not getting your problems fixed, it seems like you need to find another shop.
Get a printout of the alignment setting they used and compare them to the factory specs in the FAQ.
6spd4dsc
Mar 4, 2016 05:19 PM
Maxxx10
Sep 13, 2015 03:16 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
