anybody know how to light your exhaust on fire
Old Apr 23, 2001 | 05:59 PM
Justin95SE's Avatar
just curious, something to do with a spark plug i think.
Old Apr 23, 2001 | 06:05 PM
Sprint's Avatar
If your spark plugs are way past due.. this will cause your car to run extremly rich.. if a car is running too rich this may cause flames to come from the exhaust pipes
Old Apr 23, 2001 | 06:07 PM
Don in Texas's Avatar
Its old school stuff. Tap into your exhaust with a Spark plug, run power to your sparkplug via a relay, when you give it gas (rich condition only), the sparkplug will ignite the fumes....
Instant BBQ....
Old Apr 23, 2001 | 06:13 PM
SmoothMax's Avatar
OG
Interesting..... This has got to be illegal though right?
Old Apr 23, 2001 | 06:17 PM
Justin95SE's Avatar
ok anybody know how to do that, need directions
i need directions, i dont know the whole electronics of it, to make it run rich you can pull out an O2 sensor right?
Old Apr 23, 2001 | 06:24 PM
Sprint's Avatar
Re: ok anybody know how to do that, need directions
No that will make it run lean..
you can buy a Super AFC from Apex'i that will alow you to control the richness mixture
Old Apr 23, 2001 | 06:31 PM
Justin95SE's Avatar
are you sure, b/c i was sure that was rich
i remember somebody said that when ever they went to the track they took out their O2 sensors to make it rich and burn more fuel, then there was a discussion regarding how richer wasnt faster.
Old Apr 23, 2001 | 06:34 PM
Sprint's Avatar
Re: are you sure, b/c i was sure that was rich
No Lean is faster... pull your front O2 sensor out.. drive around with it.. and i bet you will get a Code for Knock Sensor and Lean Mixture
Old Apr 23, 2001 | 06:36 PM
Justin95SE's Avatar
you think its actually faster to pull the O2 sensors
you think its actulaly a good racing strategy to pull the O2 sensors?
Old Apr 23, 2001 | 06:59 PM
Sprint's Avatar
Re: you think its actually faster to pull the O2 sensors
I don't think you should every pull your O2 sensors if they are not bad.. they are very sensistive.. if you are that interested in getting the edge.. strip the car or something.. take all your seats out.. but don't start messing with electronics.. then you are looking at blowing your engine if you don't know what you are doing and then your have a more expensive problem and no transportation
Old Apr 23, 2001 | 07:34 PM
n2oMike's Avatar
I did it...
I did this on my 66 mustang back in high school... I'm now 33. It worked great, and shot blue flames out the tailpipes about 3ft, and made a surprising amount of noise!
To do this, a button was pushed to ground out the coil and charge a second one in the trunk that was hooked to spark plugs in the tailpipes. When the engine coil was grounded, it killed the ignition, which allowed raw fuel to flow through the engine and to the tailpipes (pumping the double pumper carb also added fuel to the fire). Major flamage were the result... too cool!
BUT, this was with a point style ignition and no catalytic converters. Grounding out the coil (or coils on a Maxima) on a modern car with fuel injection might not be a good idea... plus, the catalytic converters would burn the excess fuel in the exhaust (and glow red hot in the process).
To pull off flames in a modern automobile, I'd go a different route. A coil in the trunk hooked to sparkplugs in the tailpipes is good, but, a different fuel source is needed. Propane plumbed into the exhaust would be the route I'd take. Open the propane valve, then light the plugs!
Of course, do this at your own risk. You could cause a fire... possibly to your own vehicle. However, it would deter tail gaters.
Good Luck!
Old Apr 23, 2001 | 08:30 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: I did it...
propane..haahaa...anyone remember that pic of the maxima that had the entire trunk and house blown up?..wanna try that?
Good Luck!
Old Apr 23, 2001 | 08:31 PM
bullseye's Avatar
Re: I did it...
Good Luck!
PROPANE? How about LOX? Now *THAT* would discourage both tailgating and high-flying geese! To the Bat-cave, Robin!
Old Apr 23, 2001 | 08:46 PM
ybelm620
try running a staright pipe with a good muffler. also get a aftermarket ypipe, thats what i am doing
Old Apr 23, 2001 | 08:54 PM
Weasel's Avatar
Re: Re: I did it...
ROFL, first Maxima to achieve escape velocity!!
Old Apr 23, 2001 | 10:33 PM
dch95's Avatar
Re: Re: I did it...
LOX? Hope you got some leather gloves!! Course you could always use it for a hangover
Old Apr 23, 2001 | 11:33 PM
Jon91SE's Avatar
Pusssseeeehhhh
Hey my car seems to run really rich as well , had a full tuneup, o2 wiring redone, head temp. sensor replaced, all to no avail....any ideas?
Old Apr 24, 2001 | 05:06 AM
Daniel B. Martin's Avatar
This answer pertains to 4Gen Maximas. This information may or may not apply to your '91.
An over-rich mixture may be caused by ...
- a bad Engine Coolant Temperature Sensor
- bad Oxygen Sensor(s)
- bad Fuel Pressure Regulator
- sticking fuel injectors
- an obstructed fuel return line
Old Apr 24, 2001 | 05:34 AM
dch95's Avatar
Rich
Dirty air filter?
Old Apr 24, 2001 | 07:23 AM
mzmtg's Avatar
Minister of Silly Walks
You can get flames by mounting both a spark plug and a fuel injector in your tail pipe.
Old Apr 24, 2001 | 08:34 AM
Shingles's Avatar
The missing moderator
realize that 1) running rich will rob you of some power and 2) it will cause the...
never mind.
good luck,
-Shing
Old Apr 24, 2001 | 11:00 AM
got rice?'s Avatar
Re: Re: ok anybody know how to do that, need directions
pulling the O2 sensor makes the ECU automatically dump in more fuel, not less.
I doubt anyone on this forum will produce enough heat from the exhaust gas to ignite a rich exhaust gas mixture. If you want to do it right, you need HP to create hot exhaust pipes PLUS extra fuel to make it run rich.
If you install the ghetto "I wanna shoot flame setup" you can risk fawking up your engine by allowing the the flames to flow back into the combustion chamber. I've never witnessed it in person nor do I know anyone that has had this happen; I've only heard stories through third parties.
Old Apr 24, 2001 | 01:18 PM
maxium nrg's Avatar
I remember reading an article in sport compact car about a product called "dragon ball" or "dragon fire" that was supposed to do this. I've also heard that cars with turbos or no cat's sometimes do this.
cruce91
Sep 20, 2015 10:23 AM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
