Tranny light?
Old Apr 23, 2001 | 08:45 PM
musali's Avatar
I recently let my friend drive my '96 GXE maxima in a mall parking lot, when the dumb*$$ nuetral drops it. It had a really good peel out, but now after two days a light on my dashboard is lit up, its in the extreeme right with a picture of a motor or a tranny with the words CHECK infront of it. Is this the tranny light cuz if it is, im screwed.
thanks in advance,
newbie
Old Apr 24, 2001 | 05:12 AM
Daniel B. Martin's Avatar
Check Engine Light
thanks in advance,
newbie
The Check Engine Light is evidence that something is wrong. That
"something" may be any number of things, some major and some minor. It
might be nothing more than a loose fuel filler cap. The Engine Control
Module (the computer) detected a problem and turned on the Check Engine
Light. At the same time it stored one or more Diagnostic Trouble Codes.
Get someone to do a DTC readout for you. This is not a big deal, does not
require specialized "dealer only" test equipment, and should take less than
an hour. When you know the stored DTCs, you will have a fair idea of what
repairs are needed.
If you like to do your own "wrenching" you can do the DTC readout for yourself.
No special tools are required.
You will find instructions to do a DTC readout and reset
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
pktaske
May 6, 2016 07:49 AM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
