How do I figure out which Motor Mount needs to be replaced?
Old Jan 6, 2005 | 08:16 AM
shadygrey's Avatar
Last time I was at the shop the mechanic told me that one of my engine mounts needs to be replaced. I don't remember which one he said it was and this was a long time ago. I hear a rattle sound when i'm driving or idle sometimes. Should I just replace all of them just incase? I see a set of 3 on ebay for around $200 where at courtesy or Jerry Rome they are charging $190 just for 1.
Old Jan 7, 2005 | 08:19 AM
shadygrey's Avatar
anyone please???
Old Jan 7, 2005 | 08:41 AM
Wetballoon's Avatar
Look at the rubber, see if it has been ripped up. Also see if the metal has cracked. Last resort, take it back to him and ask.
Old Jan 7, 2005 | 09:23 AM
MrEous's Avatar
^ Jeff™
If you replace any then it would most likely be the front and rear mounts. These handle the most stress.
Old Jan 7, 2005 | 10:02 AM
1FSTMAX's Avatar
Just replace them both.. chances are if ones messed up, the other one is.
Old Jan 7, 2005 | 10:57 AM
SPiG's Avatar
SomePsychoGuy
If the metal is good then either fill them with polyurethane or get the ES motor mounts installed.
Old Jan 7, 2005 | 12:08 PM
Broaner's Avatar
2060lbs and falling...
Word! There is no point to replace them with stock. My metal sleave completely ripped away from the mount with a bit of rubber attached to it. I glued it back it with super glue and then filled it with Polyurethane as per mzmtg's write-up. I know the super glue may not stick very well to this rubber but it doesn't matter cause the sleave is completely surrounded by polyurethane. There is also no need to spend the money on the ES mounts when you can make your own for $33 and an hour of your time.
vingodine
45
May 21, 2016 12:46 PM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
