Anyone changed their "Front Strut Bearing"??
Old Jan 6, 2005 | 11:07 PM
aminus21's Avatar
My dads 95 makes a fast clicking noise AFTER turning the wheel at slow speeds. I suspect it is the front strut bearing. I have already ordered the part, and read this writeup about 100 times: http://www.motorvate.ca/mvp.php/703
I just wanna know, do I just take out the old bearing, and put in the new one?? Should I grease the new one with regular grease??
Also, is there anything special that I should look out for/replace while Im in there? I just changed the Axle last week, so I dont think this will be too hard. Also, I dont have a vice, so someone will probably hold the strut while tighten the spring compressor and remove the strut nut. Or should I tighten the springs while the strut is in the car??
Any/all tips are greatly appreciated. Thanks guys
Old Jan 7, 2005 | 12:15 PM
nitromax's Avatar
the bearing doesn't need grease, just put it in. you need to secure the strut. not just have somebody hold onto it!
Old Jan 7, 2005 | 12:39 PM
vahmed's Avatar
I have the same concern since I don't have a vice either my question is if can loosen the center nut (just 1-2 threads) while the strut is still on the car so it might be easer later? any suggestions? I need to replace the strut mounts is it a good idea change the bearings same time?
-Thanks
Old Jan 7, 2005 | 01:53 PM
eng92's Avatar
Check your strut mount insulators for separation of the rubber from the steel.
The balljoints are really easy to check once you have removed the strut.
Also both lower control arm pivot bushings should be checked for excess play while you are down there.
Old Jan 7, 2005 | 05:48 PM
nitromax's Avatar
don't loosen the nut while it's on the car. if you get the struts off of the car and don't have a way to hold them secure, take 'em to a shop with all of the replacement parts, ie: new struts, mounts, bearings, etc. it won't cost as much to switch out since they're off of the car. AND it's safer! those springs pack a lot of punch if they get loose!
Old Jan 8, 2005 | 06:37 AM
aminus21's Avatar
Can someone give me the torque numbers for: the 2 bolts that connect the strut to the steering knuckle, the 3 nuts from the top of the strut, the 1 strut nut that is removed after compressring the spring.
And the axle nut is 173 right?
Old Jan 8, 2005 | 12:58 PM
1991tsi's Avatar
Torque (these are for years 93-94, but they are close to 95+ so I suspect '90 would be similar also):
Strut to steering knuckle 116-123 ft-lbs
upper strut mount (3) 29-40 ft-lbs
piston rod nut 43-58 ft-lbs
axle to hub 174-231 ft-lbs
Old Jan 9, 2005 | 03:41 AM
eturnl
Not saying you should do this, but i didnt have a vice, and i just put that sucker between my legs and tightened the spring compressers with a ratchet. It did help quite a bit when someone was holding it for me as well. but i got it done pretty easily. once you clamp on the spring comressor tool (the set i had at least) i felt pretty safe doing what i did. you'll know what you're comfortable doing after you get started i think. just give it a go. be safe. and good luck
Old Jan 9, 2005 | 10:33 AM
redstradic's Avatar
i did the same thing, sort of. i just set the spring and strut on the ground and pushed down on the top hat with my hands. then someone just unscrewed the nut and i slowly let up on the top hat. took a min to get them apart.
Old Jan 9, 2005 | 02:43 PM
1991tsi's Avatar
If its an old strut that you're replacing, you can put vice grips on the piston to keep it from rotating.
kingw323
20
Oct 21, 2015 08:36 AM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
