O2 sensors bull/ Bank 1 sensor 2
Old Jan 7, 2005 | 02:05 PM
floridamax's Avatar
Hello all,
Where exactly is the Bank 1 sensor 2 located? Dont have a haynes or factory maual. Any link to a pic or even a crayon drawing would be great too. Thanks in advance.
Old Jan 7, 2005 | 02:12 PM
caudio51's Avatar
there are three sensors on the car if i remeber correctly,
The two upstream sensors(one per cylinder bank) and one downstream sensor after the catalytic converter.
Not sure what you mean by banks
Old Jan 7, 2005 | 02:14 PM
floridamax's Avatar
Old Jan 7, 2005 | 02:48 PM
Ant96GLE's Avatar
Banks mean either the front set of cylinders or the rear set of cylinders
Old Jan 7, 2005 | 02:54 PM
caudio51's Avatar
duh, how the hell didn't I pick up on that. The Haynes manual does not tell how to tell between the two sets of banks however.
Old Jan 7, 2005 | 07:31 PM
Jatan's Avatar
http://www.jatan.net/02Sensor1.jpg
Old Jan 7, 2005 | 07:59 PM
caudio51's Avatar
Originally Posted by JaTaN
not correct for his year max, I am guessing that he does not have a california model
Figure 2 1999-2000 California Maxima; all 2001 Maximas; all 2000-2001 I30
Figure 3 2000 California Maxima; 2001 Maxima; all 2000-2001 I30
Old Jan 7, 2005 | 09:07 PM
Jatan's Avatar
I don't think the bank numbers change...
Here's the cylinders/banks from a 97 FSM:
Old Jan 7, 2005 | 10:11 PM
eng92's Avatar
Originally Posted by floridamax
Hello all,
If your 99 is Fed Spec (3 O2 sensors), bank 1 sensor 2 is downstream of the main cat.
If your 99 is Cali Spec (4 O2 sensors), bank 1 sensor 2 is downstream of the pre-cat coming off the rear bank (firewall side) of cylinders.
Old Jan 8, 2005 | 06:52 AM
floridamax's Avatar
thanks for the help
Old Jan 18, 2005 | 01:06 PM
caudio51's Avatar
So my code is for downstream O2 Sensor, I have a cali spec car, oxygensensors.com lists two walker O2 sensors for the car....which to get???
One is part # 250-24284 for 84.50 and the other is # 250-24286.
Also, is the only way to know if I have three or four sensors to get under the car??
Old Jan 18, 2005 | 06:52 PM
eng92's Avatar
If your car is a 99' Cali-spec, you have 4 sensors. Both rear sensors are 4-wire zirconia type.
The reason for the two different p/n is that the length of the potted-in cable is different. Sensor is the same but one cable is 8" longer than the other.
You will have to look under the car and see if the one that has to be replaced has the longer or the shorter cable.
Old Jan 18, 2005 | 07:23 PM
caudio51's Avatar
Another question. my code is 0510 Downstream O2 Sensor Max Voltage Monitor Fault.
How do I know which downstream sensor it is? Or do I just have to replace both?
Old Jan 18, 2005 | 08:04 PM
eng92's Avatar
ECM 0510 corresponds to GST P0138 which is bank 1 sensor 2. Rear bank (firewall side) sensor downstream of the cat.
Old Jan 18, 2005 | 08:07 PM
caudio51's Avatar
Thank you for the info. Where did that come from? I'd like to read up a bit more.
Old Jan 18, 2005 | 08:17 PM
eng92's Avatar
FSM, the best $40CDN I ever spent.
Old Aug 2, 2012 | 01:45 PM
Muff Doc's Avatar
Bank one means cylinder 1 and bank 2 is cylinder # 2. Hope this helps you to know what banks are on an engine
Old Aug 2, 2012 | 01:55 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Welcome to the board Muff Doc...the post you just bumped is from 2005...if you look just over the posters name it tells when it was posted. On this board they will flame you mercilessly for said activity just a note. take care.
Old Aug 2, 2012 | 01:57 PM
Amerikaner83's Avatar
^^ gentle...not the style of most.
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
