Really bad starts...help
Old Jan 9, 2005 | 01:24 PM
Sentinal's Avatar
I've been having this trouble for awhile now. Whenever I try to turn the car on It hesitates for like 3 seconds, then starts. Sometimes it doesnt even start on the first or second try. I had my battery replaced 2 weeks ago and the cables look fine to me. Today I decided to clean the TB to see if that was the solution, and I also checked the Camshaft Position Sensor which I believe is where the Timing Chain cover is. I unbolted it and didnt see any metal shavings on it, just saw oil on it.
Now when I try to turn it on it gives me even more trouble and its not even starting. Sometimes it cranks and when I give it another try it doesnt crank at all. Is there something else that can be causing this? Please help
Old Jan 9, 2005 | 01:45 PM
Sentinal's Avatar
bump......
Old Jan 9, 2005 | 01:57 PM
Viscous's Avatar
sounds like your starter is on it's way out. even if your sensors were busted, the starter would still try to crank, so it's definitely not your cam/crank sensors. Did the starter ever make any screeching noises on occasional cold starts? That would be an indicator of a sticking/stuck starter that could benefit from a regreasing.
Old Jan 9, 2005 | 09:41 PM
Sentinal's Avatar
Now it doesnt even crank. I just hear a brief "click". Is it because I kept pumping the gas, while it was trying to crank up? What is happening?
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
