ECU code 1205 problem
Old Jan 9, 2005 | 06:15 PM
Vlad's Avatar
Unfortunately I can not open a link that refers to more information about Line Pressure Solenoid Valve (AT)
I have a 98 GLE and few days aga, on a trip to a West Virginia, I started to have problems with my AT. First to second is very hard right now, especially if my car is warm. 2 to 3 gear is better (almost unnoticable) and there is the same thump going from 3rd to overdrive...
I just checked my ECU code and it is 1205 but I have no idea how bad it is and what needs to be replaced. If there is more info about 1205, can you pease post it here, since I can't view this link...
1205
http://forums.maxima.org/search.php...rder=descending
If any of you have any information about this please post it.
Thanx!
Old Jan 9, 2005 | 07:26 PM
mansurxk's Avatar
isnt that indicative of a bad drop resistor? i think thats the code you get when you use the drop resistor mod, giving you full line pressure. might want to check that out
Old Jan 10, 2005 | 01:36 AM
Vlad's Avatar
I don't know anything about bad drop resistor.. I didn't do any modification to my car and it has 127,000 miles on it.
I have this Haynes repair manual and it says that it's a line pressure solenoid or curcuit fault... see I am not a technical guru, so I need help with that...
gustavison
Oct 4, 2015 06:50 PM
QueensMAX
Sep 15, 2015 04:14 AM
jwright36
Sep 8, 2015 11:45 AM
mix master
Sep 4, 2015 05:50 PM
