airbag light came on
Old Jan 10, 2005 | 05:29 AM
tonymich's Avatar
After leaving the sunroof of my 1995 SE open during a rainstorm, the airbag light came on and hasn't gone off. Is there a reason to be concerned about this? Does this mean that the airbags won't work or simply that the sensor got wet, and perhaps rusty?
is there a way to reset (turn off) the light to see if it comes on again?
Thanks.
Old Jan 10, 2005 | 06:51 AM
FormorAccordMan's Avatar
You can try the airbag reset procedure. Put the car in the accessory position, press the drivers side door sensor (the rubber thingy that presses shut) 5-6 times. then start the car.....I think.
Old Jan 10, 2005 | 07:10 PM
Crockpot's Avatar
Originally Posted by kevlo911
How to reset SRS(air bag) light
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
obtained from 4th gen How to's
Old Jan 10, 2005 | 07:20 PM
Bags's Avatar
VG Ridah's Biatch Hoe
And for tonymich, if that does nto fix it, take it to be checked/serviced.. you can kill yourself working on an airbag
Old Jan 10, 2005 | 07:58 PM
SXN's Avatar
SXN
if the procedure to turn it off doesn’t work after a couple tries, get it serviced. that means something really is wrong with the air bags, and this isn’t the area to ignore a warning light. if the sensor is having a short, or value fault, the bags could not deploy during an accident, or deploy unecessarily.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Colossus
Sep 9, 2015 05:46 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
