Knock Sensor removal problems
Old Jan 10, 2005 | 11:14 PM
Chino's Avatar
I finally replaced my knock sensor and WOW what a diffrence! She pulls a lot harder off the line now! However in the process I couldn't remove the bad sensor from the wire harness. After about half an hour I finally managed to pop it out of the harness but the harness broke a little. The top part of the wire harness that clicks on to the sensor broke. I checked and the new sensor held its place without the locking device. Once connected I bound the knock sensor to the harness with electrical tape. Is this going to be a prolbem? I'm mostly afraid of the tape melting and damaging the connection. On top of that the knock sensor code still poped up when I got my smog check. However I think that might be because I didn't reset my ecu (disconnect my battery). Should everything be okay? Thanks.
Old Jan 11, 2005 | 08:16 AM
mu_max's Avatar
I too had a bit of trouble figuring out the connector but I used a really small screwdriver and was able to remove the wire that holds the sensor on. I did break off a small piece of the connector but was fortunate that the connector still functions properly.
Hopefully the tape will hold for you and not melt either. I think as long as the contacts are holding you should be allright.
Check you CEL every now and then for the first few weeks and if it is throwing the code you may want to revisit the connector issue. If it doesnt throw the code, leave it alone.
Old Jan 11, 2005 | 08:20 AM
MAXRB8's Avatar
You should be okay as long as you taped it well, reset the ECU, you'll know soon enough
Old Jan 11, 2005 | 07:13 PM
Chino's Avatar
So far so good fellas. I haven't checked for the code but the car's torque is beautiful! I was so used to having a bad knock sensor (1yr) that just by replacing it, it feels like I got a mod! I can't stress how much more enjoyable the drive is now.
Old Jan 11, 2005 | 07:27 PM
l3ftonm3's Avatar
Yah I know what your saying I was in the same situation then I changed it last week and what a difference it did make. It dosnt lag anymore when applying the gas, plus It seems like my rpm's are a little lower when Im just crusing at 70, they are right around 2100, used to be 2500ish
Old Jan 11, 2005 | 07:51 PM
Crockpot's Avatar
how many miles did your guy's knock sensor have on them when u replaced them? I'm wondering if I should spend the money to replace it or not
Old Jan 11, 2005 | 07:53 PM
Chino's Avatar
Oh btw my old knock sensor was cracked! No wonder is was bad....
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
