Polishing Mevi (Pics)
Old Jan 11, 2005 | 10:38 AM
SMX95's Avatar
Ive had this mevi for about a month now. For the past 2 weeks ive been hand sanding it. I did about 2 hours of 400 grit wetsanding on it today to give it a very nice polished look. I know I have more to do but its getting harder and harder to get everything smooth around the tubes. Is there another way for me to do it?
Old Jan 11, 2005 | 10:46 AM
Jeff92se's Avatar
I'm needing a caw
You are in for one hell of a time. ESPECIALLY if you are hand sanding. I did my 300z calipers and I won't do that again!
You should get an electric drill and some flapwheels. They work great for flat surfaces. But you did most of that anyway. You could have accomplished what you did in the pics in 1/4 of the time. If you get a smaller flapwheel, you can get into most of the areas you haven't touched yet.
To get into the small areas, get a dremel and a bunch of small sanding drums. But you have to be careful not to grouge the alumin. But it's the only way to get into the small areas. You will probably have to finish off by hand too. Big pain.
Finally you will have to finish it off with a high speed grinder + a polishing wheel + polishing compound. I've skipped some steps but you get the idea.
Some pics:
Old Jan 11, 2005 | 11:06 AM
sterlingmaxima's Avatar
""f"" that get a dremel with a polishing kit does wonders!!!
Old Jan 11, 2005 | 11:08 AM
Jeff92se's Avatar
I'm needing a caw
Yeah, he will be there until the 10th gen maxima comes out if he does the whole thing with a dremel.
Old Jan 11, 2005 | 07:59 PM
SMX95's Avatar
yeah If I keep going by hand it will take me another 2 weeks to finish. I can't do it anymore by hand. I got the dremel today with an accessory kit. Im set to go and spend about 4 hours on it tomorrow. I want it done and im ready for it. Thanks again jeff and nice brakes they came out great!
Old Jan 11, 2005 | 08:18 PM
Irish's Avatar
This is a democracy
looks good, and jeff those calipers are really nice, keep us updated
Old Jan 11, 2005 | 10:16 PM
Maximeltman's Avatar
yes...they are.
Old Jan 11, 2005 | 10:18 PM
Jeff92se's Avatar
I'm needing a caw
They have been installed for about a year? I clear coated them. Being holding up fairly well. See sig pic. Here is one from the day they were installed
Old Jan 11, 2005 | 10:22 PM
looking real good. I need to start upgrading my own brakes here in a bit.
Old Jan 12, 2005 | 12:25 AM
Ninos_Maxima's Avatar
be the change u want2C
Just get a dremel, might takes some time like Jeff Said, but its perfect for getting into those tiny little spaces, Go buy a polishing kit with it to, works wonders.
Old Jan 12, 2005 | 04:09 AM
Ceasars Chariot's Avatar
Old Maxima Legend
hey the mevi is coming along nicely !! keep it up !
Old Jan 12, 2005 | 04:49 AM
stephenlc's Avatar
it takes a long time even with a dremel.
Best way is to go over it with sand paper first to get off all the dirt and some of the roughness in the intake manifold. Then wipe it down. Then take the dremel to it and have lots of sanding wheels. Then go over it with polish.
Old Jan 12, 2005 | 06:43 AM
SMX95's Avatar
Thanks for all your replies. Yes I bought the polishing kit that it comes with as well. Should i just use that instead of mother's aluminum polisher? If I have some time today I will work on it. Since both of my parents went through surgery I have to be there for them when they need something so its pretty hard to find a good amount of free time. Anyway ill keep you all updated. Has anyone else polished a mevi?
Old Jan 12, 2005 | 09:38 AM
2 Da Max's Avatar
edit
i did my valve cover by hand and with a drill and an aluminum wire brush tip. tookabout an hour. i used nexxon aluminum polish also. I mean it doesnt have that chrome look but its shiny.
rockfordmax, its a circular brush that is made out of steel or some kind of metal.
Old Jan 12, 2005 | 09:42 AM
RockfordMax's Avatar
Back from the dead
can you post a pic of the brush you used, because i wanna polish a bunch of stuff, but have no clue how to do it. thanks
Old Jan 14, 2005 | 02:26 PM
SMX95's Avatar
Update
Here's an update on how it looks. I think i have a bit more to do and then im done. Im going to do more 600 wet grit on the tubes. I highly recommend this bottle that I used. (look at pics). It has very very fine grit in it so when used with a buffer or dremel it does wonders. I recommend it more than mothers aluminum polisher. Here are pics. I will also take pics of the dremel accessories
Old Jan 14, 2005 | 02:45 PM
RA112325's Avatar
Have it bead blasted and be done with it!
Old Jan 14, 2005 | 03:03 PM
SMX95's Avatar
Bead blasted? Anyway its not as easy as you think. But at least im trying to get it done while having a million other things in line to do.
Old Jan 14, 2005 | 03:22 PM
RA112325's Avatar
Yes, bead blasted(microscopic form of sand blasting). It's easy, it looks clean and it's done quick, ready to install. Your hard work polishing the MEVI will oxidize and you'll have to keep polishing it periodically if you want it to shine. Just my two cents.
Old Jan 14, 2005 | 03:47 PM
SMX95's Avatar
Oh ok, I fig it had something to do with sand blasting. Im cool im kinda short on cash man lol. I wish I had some to do everything. I might be lucky in that my friends father might port and polish the inside, which would be cool. Thanks for your reply.
Old Jan 14, 2005 | 05:05 PM
RA112325's Avatar
No problem. Best of luck with it, I'm sure it will come out very nice. Enjoy the new found horsepower nonetheless. :-)
Old Jan 14, 2005 | 06:54 PM
GLEtotehMAX's Avatar
is bead blasting the same a glass beading?
Old Jan 14, 2005 | 09:22 PM
Spaniard's Avatar
Looks good from the outside. Any chance that you can do something to the inside to get more HP? like emulate extrude honed?
Old Jan 14, 2005 | 09:36 PM
Supermax95's Avatar
I told you to get the Dremel (this is "Phatbashar").
litch
123
Jan 4, 2024 07:01 PM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
JonBlz
Oct 5, 2015 06:02 PM
bigfrank
Oct 1, 2015 12:51 PM
